TR2/3/3A Seized rear brakes
59Rob
My TR3 has sat for a very long time, the rear brakes are seized bad!
Any TR specific tricks to getting the drums off? They don't turn at all and it's quite the mess at the backing plate so I can't tell if there's a star wheel adjuster?
Thanks for any suggestions!
CJD
No star wheel. Opposite the cylinder there is an adjuster with a small square headed adjuster on the back (inner) side of the brake back plate.
DavidApp
There is a special square wrench for the adjuster that will help prevent you from rounding the corners of the adjuster. The adjuster may be frozen in place.
Had to get the rear drum off a friends TR3B and I managed that by hammering on the drum but it is hard to get a good swing at most of the drum.
A large gear puller may work.
Good luck.
David
mastaphixa
Bronze
The 5/16 square drive wrench is really a good tool to have for this. I was able to use a 8pt socket but intend on getting the wrench with my next Moss order.
karls59tr
Bronze
Also check the the rear rubber brake lines as they may have collapsed and the blocked lines are preventing brake fluid movement.
59Rob
Thanks guys, I'll have a look for that adjuster and I should order that wrench. I'm not a big fan of these square bolts. Couldn't get the oil plug out either.
I'll check the brake lines too but I'm pretty sure rust fusion is the main issue.
charleyf
And lastly if you are not familiar with these brakes there are two screws on the front (outside facing) of each drum. Those hold the drum onto the axle.
sp53
Worst case you will need to bust the tin backing plate free (probably with chisels and whatever---- it is a 3 pieces system of tin) on the wheel cylinder to break the adjust free to move and to buy you some space for the shoes to move into and free the drum.
steve
Madflyer
Some times problems can only be dealt with a bigger hammer. A good hit on each may let the springs move the shoes. In any case it will be tight at best.
Bob Claffie
If you try to loosen the adjuster with the square fitting be aware that as that square fitting begins to turn it also EXPANDS the "pegs" inside the wheel cylinder until it has gotten over the first ramp of the adjuster making the drum all the tighter.
K TR2/3/3A TR3 rear brake adjuster seized? Triumph 10
Celtic 77 MGB Seized air pump issue MG 25
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
Joe Schlosser Seized Clutch Spridgets 10
aeronca65t Seized Landies Rover / Land Rover 13
JPSmit Viva GT question [seized engine] Other British Cars 5
B TR2/3/3A TR3B Handbrake bolt seized Triumph 5
Geo Hahn MGA MGA w/ Seized Engine MG 6
theleisure Seized 1275cc, What the...? Spridgets 22
R stuck/seized distributor--please help! MG 21
B MGB 72 mgb speedo drive seized.....easy fix? MG 11
B seized my engine???!!!! Spridgets 60
ahpook what's a 79 midget with a seized engine worth? Spridgets 2
John Moore Un-seized! Spridgets 7
T TR4/4A TR4 Seized [?] Engine Triumph 12
kindofblue Front Dust Caps Problem & Seized fuel Sending Unit Triumph 9
L Seized Pistons MG 16
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
