TR4/4A Replacing Front Windshield Gasket
KVH
I replaced my windshield gasket last evening, all by myself. I don’t know whether I should be proud or ashamed. I can still hear myself grunting and squealing. I don’t know why I do these things. I am aching, and feel that I’ve aged significantly since last evening.
National Auto Glass at Grant & Stone did mine for 40 bucks.
Maybe you need to learn to pace yourself and pick your fights.
No, I had the windscreen frame off the car (which was why I couldn't do it myself). Even they agreed (after the fact) that it was a job to wrassle that thing to get the glass in.
BTW - the $40 was a few years ago so the price may have gone up. To their credit, they quoted 40 when I took it in and stood by it.
Assuming I ever do this again, how does that string trick work? I assume you drop it behind the lip, from inside the car, and then pull in toward the interior of the car? In other words, the trick is to pull the gasket lip in without having to slide a "non-sharp" tool into the track?
Yes, run it around then inside of the lip. I have done it twice. The first time worked. The second the string broke and my not gentle enough persuasion with a screwdriver (I was trying to pry the rubber and stay away from the glass) broke the glass, in hindsight wrong tool, wrong method, all kinds of wrong.
Rather than risk breaking another I had the replacement installed at my house. I watched the guy do it and took notes. My idea of using twine was all wrong, I thought thin would be easier to pull out. It wasn't, it dug into the rubber in spots instead of pulling it out, and it broke eventually. The installer used a fairly substantial nylon cord, probably somewhere in the 1/8" to 1/4" inch range. Tuck the cord under the inner lip with the two ends meeting in the middle at the bottom. Lubricate it with soap. Push it in from the front as best you can, especially on the bottom where you start pulling the cord. Slowly pull the cord out, the corners can be tricky, and heel of the hand pressure on the outside of the windshield will probably be needed at the same time you pull the cord. It is all pretty slick when it works right.
I was gun shy after the breakage, but wouldn't hesitate to do it myself again if needed now that I have seen the proper tools and techniques. Greg
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
M Replacing front shocks, torque setting? Spridgets 2
RJS TR4/4A Replacing front brake hoses Triumph 10
RickB Replacing 12 front bushings today Spridgets 15
J Replacing front shocks. Austin Healey 3
B Replacing Front Seal Spridgets 3
R Replacing Front Hubs and Bearings Austin Healey 8
Whytock Replacing Front Signal Light Lens MG 1
B TR6 replacing U joints Triumph 4
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
