    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Replacing Front Hubs and Bearings
Richard Dickinson
I am replacing all of the hub extensions due to wear of the splines. I had intended to reuse the bearings on the front hubs. However, I am finding it difficult to get the bearing races out, /ubbthreads/images/graemlins/confused.gif since they are an interference fit. The shop manual says to punch them out with a drift. Since there is very little "lip" to drive against, it looks like the races will be pretty well destroyed if I can get them out at all. So I will have to get new bearings. My questiion is, how to get the new races in. I'm thinking that I might heat the hub to expand it and chill the races to contract them and drive them in. If anyone has done this I would welcome advice.
Richard,
Look carefully at the hub around the lip of the race. There are two machined reliefs, 180 degrees apart that give you more room to punch out the race (at least there were on my BJ7 hubs). When I replaced my bearings, I put the races in a ziplock in the freezer overnight, then put the ziplock/races on ice in the shop until ready to install. I put the hub in the shop oven, approx. 160 degrees F for 15 minutes. I found an ABS coupler that was the right size for the race and used that to drift the race in. I think they tapped in easily but that was 4 or 5 years ago and the memory isn't what it used to be. You could go to a machine shop and have them pressed in. I do remember the rotor studs being much more difficult to drift in .. a machine shop would be the easiest way to do that part.
Cheers,
John
Hi Richard, Installing the new races can be achieved by grinding the outside diameter of the old ones down just a bit and using them as the driver.Fitting a short pipe nipple of the proper diameter on top of this will allow you to drive them home.Final seating is done with the wheel assembled and installed on the axel.---Keoke
Thanks for the advice. I have a Harbor Freight press that I used to press the studs in with no problem. I may just take the hubs to a shop and let them press in the races. My wife dosen't take kindly to me baking auto parts in her oven.
I got the bearing races in today. Turned out to be fairly easy. I found two sockets that were the right size to drive the races in. It was a cool day today and I had the wood stove in my shop going so I just sat the hub extensions on the stove a few minuits to heat and the bearings went easily with my press. Never was able to get the old inner races out. The outer races came out because there was a notch to allow the punch to drive against the race. There was no notch for the inner races. If anyone uses the old races to drive with be sure and don't forget to grind them down. The first one I drove in, I skipped this step, and since the recess is not as deep as the bearing, the old race got stuck and I had to drive the race out partially to loosen it.
"I skipped this step" /ubbthreads/images/graemlins/shocked.gif See I towed U to grind em down. So, thats what chu get when you don't mind your elders.---Keoke- /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/angel.gif
[ QUOTE ]
[/ QUOTE ]
Richard, when I got new hubs (about 4 years ago) they had small reliefs/notches for the inner race too. They were smaller and harder to see but you might want to check again.
I just reinstalled my hubs last weekend .. make sure you get the shim thickness setup correctly (per the manual). I used light oil only on the bearings while adjusting the shim stack float (or lack thereof) then dis-assembled, greased the bearings and assembled for a final time.
Excellent technical article on this here:
https://www.vintage-sportscar-touring.ca/technical/frontwheelbearings.html
Cheers,
John
Jest don't put nothing on them during the adjustment phase,makes handeling a bit easier.You know they wont stick together.---Keoke- /ubbthreads/images/graemlins/grin.gif
The new hubs have a notch to access the back of both bearings. The old ones only had a notch to access the outer race. Glad I read the above advice about not greasing the bearings before adjustment. I just bought a new can of axel bearing grease and intended to install them tomorrow.
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
M Replacing front shocks, torque setting? Spridgets 2
RJS TR4/4A Replacing front brake hoses Triumph 10
RickB Replacing 12 front bushings today Spridgets 15
J Replacing front shocks. Austin Healey 3
B Replacing Front Seal Spridgets 3
Whytock Replacing Front Signal Light Lens MG 1
B TR6 replacing U joints Triumph 4
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
