Replacing Bugeye windshield rubber
drooartz
I need to replace the windshield -> car rubber seal on the Bugeye in order to get it mounted back on the car for shipping. I've got a new seal in hand, but I've not done this one before. Do I need to remove one/both of the stanchions in order to slide on the new rubber, or is there another approach?
mezy
Not done one on a bugeye before but i have allways pulled them in with a cord placed in the groove of the rubber get some one to put some weight on the screen the pull on the cord to pull the rubber into the frame
Im sure some one will come along with another sugestion,
Bayless
Not a bugeye but on my MKIV we removed one post and with three sets of hands pulled it in. One pulled from the end and the second pushed from the other. After it got about half way, the third kinda pulled from the middle. We used lots of soapy water for lubricant. We first tried the method John Twist showed by not removing the post but wasted a whole day with not luck at all. The far bigger problem, however, was getting that new seal squished down enough to get it in the car and the mounting bolts installed. Also, there was a rather large gap between the posts and the body where the bolts install. If you don't have your original spacers, you will probably need to make or find some as Moss shows them N/A. Mine needed about .140 inch each.
Platinum
Soapy water is a poor lube for this job compared with glycerine, a drug store item (and water soluble for cleanup). For a "cord" a better tool is coated copper wire... 12 gauge coated. Worked on British car glass installs for decades for us.
drooartz
drooartz
Thanks for the tips all. My wife and I (I owe her now) got the rubber installed and the windshield on the car tonight. Took off one of the stanchions and the new rubber slipped right in. Used some soap and a bit of twine and it's all on the car.
Funny, the pic looks like I just need one good weekend push to finish it off. If only. ;)
Bayless
Congratulations.Glad it went smoothly. Looks like you are just about "there."
B TR6 replacing U joints Triumph 4
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
tomshobby replacing water pump Spridgets 1
D TR2/3/3A Patching, versus replacing floors? Triumph 15
T Replacing the crank pulley/damper Austin Healey 4
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
T TR4/4A Replacing Drive Train Seals Triumph 5
