Question: diff drain plug
drooartz
My differential drain plug leaks just a little bit. Do I use something like teflon tape on the threads to stop this?
Yep
A little teflon tape will do the trick
Cheers
Mark
NO!!!! IT'S SUPPOSED TO LEAK !!!! How will you know where to park your car if there is no oil spots on the ground ?!?!?!?!?!?!
Your car will freak out and just keep driving through the wall as it won't know it's time to stop. :jester:
Teflon tape will do it.
Clean the plug and threads off well, apply the tape to the plug threads.
Worked like a charm on mine. :yesnod:
I'll have plenty of other places to have leaks from. :smile:
Thanks all for the tips. Teflon tape it is.
BTW. that plug is a 7/16 square drive. I ground down two sides of a old 1/2 drive extension to make one.....
m
B TR6 TR6 Diff. Drain Plug Question Triumph 5
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
Willie_P Quick question: rear diff TR 3/4 Triumph 6
Monark192 MGB MGB Diff Thrust Washer Question MG 2
D GT6 GT6 Diff Question Triumph 6
M_Pied_Lourd TVR Diff Question TVR 1
StupidHippie Really dumb diff mount question? Triumph 12
B 3.9 Diff/half shaft/spline question. MG 2
hondo402000 TR6 TR6 dropped the Diff out and half shaft question Triumph 2
A Spitfire Spitfire diff question Triumph 14
J TR6 'nother question about the diff on a tr6 Triumph 9
jlaird Question - pulling diff seal Spridgets 3
bigbadbluetr6 TR6 TR6 Diff. question Triumph 6
SherpaPilot TR6 New Ammeter Install Question Triumph 5
R MGB 74 MGB Chrome bumper Grounding (Polarity) Question MG 7
D TR2/3/3A Question about bushing on the upper suspension.... Triumph 13
T TR2/3/3A Question regarding carpet installation Triumph 5
K TR2/3/3A One more coolant leak cylinder head question..... Triumph 5
Ohiobugeye cOIL qUESTION Spridgets 5
M MGB Disributor clamp question MG 2
K TR2/3/3A Cylinder head stud height question? Triumph 4
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
jehuie HS2 carburetor question… now with video! British Motor Corp 20
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
