Payen Head Gasket
Cutlass
Ok, go ahead and laugh, but which side goes up with the Payen head gasket on my 66 BJ8? I believe the proper side up is the copper side, but there is no imprint confirming that. The other side is a light composite. Thanks.
C
Cutlass
Perfectly? Nothing is perfect, but I did try on the gasket both ways, thinking that there must be only one correct way, and it seemed to fit both ways.
Dave Russell
Yoda - R.I.P
This type of gasket as well as the two metal sided gaskets are usually installed with the rolled over ring around the cylinders (fire ring) facing down, against the block. The solid non ring side toward the head. In your case, copper side up. There "might" be exceptions but I am not aware of any.
I'm surprised that a "real" Payen gasket is not marked.
C
Cutlass
Ok, problem solved. Roger was right. It only fits one way. I think I tried it on the first time before installing the studs. With them in, the gasket misses a couple of the studs. The label on the packaging says Payen, but the gasket is definitely not stamped to indicate which side is up. No need, really. Thanks for the prod, Roger.
Johnny spit
Hi, I have an original payen head gasket for 1300 flat , but it only says made in england on one side, no TOP ? can anyone tell me which way is up please , there is a difference around the rings, one side they are complete metal rings and the other they have a smooth part between chambers ,
Thanks
twas_brillig
A non-helpful digression: Nice to see the late, lamented Dave Russell (one of the Gods who were Good Guys) in a thread. And if you and Indiana Jones find anything else in that tomb..... (kindly smile!) Doug
J Spitfire Payen Head Gasket -which way up ? Triumph 6
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
G Payen XK engine head gasket -- which side is the top? Jaguar 2
Michael Oritt Payen head gasket question Racing 5
64rocksprite Payen head gasket...mislabeled? Spridgets 3
Morris Payen Head Gasket Spridgets 18
KVH Payen Head Gaskets Triumph 4
DrEntropy MGB What th' heck happened to Payen?!? MG 17
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 0
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
KVH General Tech Head Gasket Sealant Triumph 4
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
T TR2/3/3A Water pumps/head cooling Triumph 22
