Oil Plug in Heater Water Valve Hole
rckuhlman
Looks like somebody put an oil plug in the hole where the heater valve should be on my a cylinder head I bought. It does not want to come out and I am stripping the head. Any suggestions?
NutmegCT
Welcome to BCF. What car (model, year) do you have?
If it's just a stuck bolt, I've used a 50/50 mixture of ATF and acetone, dripped down around the hole. Let it sit overnight, then next day actually try to "tighten" it just a bit. That can loosen it up enough for the ATF/acetone mixture to seep down inside more. Tighten a bit, then loosen; tighten a bit, then loosen. Drip the ATF/acetone around the hole after every tighten/loosen round.
You usually find that after the first cycle, it will begin to loosen.
Let us know how it goes.
Tom
TomMull
If you can't get it out with ATF Acetine (or PB Blaster or the like) I'd suggest a bit of heat. Concentrate it on the plug and use sparingly. I've never removed that plug or fitting with heat but have put plenty of heat to manifold studs and an occasional thermostat housing with good results and no warpage. Check the business surface for flatness after, just to be sure.
Tom
Geo Hahn
If I recall correctly -- that hole is expecting a tapered thread on its fitting (which could be a plug on a car w/o a heater).
Not sure what you mean by 'oil plug' -- some sort of galley plug? -- but if it is a straight thread in a tapered hole it would be stubborn.
Can you tell what the plug is made of? -- that might suggest what your options are if heat & brute force do not move it.
CJD
Heat the plug red then let it cool. It should turn right out afterwards. A lot of folks use sealant that glues a tapered plug in place. The heat takes care of that too.
If it is already stripped...I would forget about the heat and get out my 1/2" drill.
TR3driver
Great Pumpkin - R.I.P
We don need no steenkin heaters !
Gordon_Dedrick
Funny thing about heaters..........I had to make an appointment for service for my daily driver, a Honda. Carole and I drove the TR3 to the dealer. It was one of the first really warm days here in NC. All the service personnell came out to look at the car and I made them all laugh when I had to open the bonnett to shut off the heater!
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
B TR4/4A Oil Drain plug size Triumph 14
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
J TR2/3/3A Oil drain plug stuck Triumph 10
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
Marla TR4/4A Oil Drain Plug Triumph 4
tinman58 TR5/TR250 Aluminum oil galley plug Triumph 1
Gerard Oil gallery plug Spridgets 12
dcoplan Spark plug and oil change question Spridgets 9
Tim Tucker Front Engine Oil Galley Plug Triumph 10
KVH Leak at Oil Drain Plug Triumph 12
TRclassic3 TR6 TR6 Leaking oil gallery plug Triumph 5
W Oil leak around spark plug Triumph 6
J TR2/3/3A TR3 Oil Galley Plug, HELP!! Triumph 4
CinneaghTR Thread Pitch for TRactor Oil Drain Plug Triumph 8
L What size and thread pitch oil drain plug? Spridgets 5
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
KVH TR4/4A TR4 Camshaft Oil Plug-Help Triumph 4
HEALEYJAG 100 BN-1 differential oil plug Austin Healey 2
B TR2/3/3A TR3A Oil Gallery plug Triumph 6
Stewart Leaky transmission oil drain plug MG 3
H MGB-GT Where is the gearbox oil filler plug on a 67 GT? MG 3
RandallRK Differential oil drain plug Austin Healey 13
dingleberry3343 74 midget 1275 oil galley plug Spridgets 6
J Oil Pan Plug Gasket [New or Reuse?] Austin Healey 9
B TR2/3/3A tr3 transmission oil fill plug Triumph 18
tomshobby Oil pressure switch electrical plug? Triumph 20
H Where is the Overdrive Oil Drain Plug and Filter? Austin Healey 2
KVH TR4/4A Rear Oil Galley Plug and Flywheel Bolts TR4 Triumph 6
B Changing Oil - Can't Remove Sump Plug - Size? Austin Healey 11
B TR6 Spark Plug - oil fouling '73 TR6 Triumph 6
RSMTR8 Wedge TR8 Oil Drain Plug Triumph 1
B Oil Galley Plug Problem Triumph 2
78MGB Oil Drain Plug Washer *DELETED* *DELETED* MG 3
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
