MGB no start, no sound from solinoid
Sopwith_Camel
1968 mgb.
the car has always started right up.
i was at the shops the other day got back to the car turned the key and nothing, no clicking from the starter solenoid. i poked at the wires under the hood. and at the white under the dash. and then it started.
i got it home and tryed to tighten the wires at the solenoid but the nut just turned and wouldn't cinch down and make a good electoral connection, so i order a new one.
I put the new solinoid in yesterday cleaning up the contact from the solenoid to the starter.
I got power back but Im still not getting anything to the starter.
I checked the ignition switch, the battery kill switch, the wire from the ignition to the solenoid.
oh this solnoid had an extra small spade connector I use the one closest to the main contact where the power comes in from the battery.
when it stops raining i will go out and try to re run the line from the ignition.
Raining? I'm betting your ground wire/strap has finally deteriorated and no longer completes the circuit to your starter.
I had that happen on a 1955 Jaguar, after washing it (and spraying the undercarriage) on a hot, humid day.
I'm betting two wires backwards - don't ask me why I think that.
the starter was dead, i waked it a few times but. no luck. I. found one in the shed fitted the new starter soolinoid then reliesed it was for a jag and had the opening on the wrong side. finaly i pulled the high torque one out of the GT and put that one in. Im hopeing to sell the roadster at an event tomarrow, hence the stress and working in the rain. fine the GT can be dead for a week.
moss has brush replacement kit. is that something I could do myself?
I'm not sure how different your 1968 is from my 1970, but mine also has a relay up inside the engine compartment that triggers when you twist the key, just has slide-on spade lugs. If thats not triggering you'll never get power to the solenoid lug on the starter.
i havent seen any relays. the pervious owner sent in for restoration in poland, and the wireing harness was a mess when i got it. for exsample the light switch would turn off the car. so there might be some gremlins I didnt find four years ago.
I just poked around with some wiring diagrams - (using the Advanced Autowire diagrams which apparently were originally published by Bentley). Some 1968's apparently did NOT use a relay (diagrams listed 1967-1968 and 1968-1969), the white with red stripe wire goes directly from the key switch to the starter solenoid. On another diagram (listed as 1968-1970) the white with red stripe wire goes to a relay (probably added because of the amount of current draw) which has a different wire (white with brown stripe) running down to trigger the starter.
So 1968 may or may not have a relay - if it does, it would be a square-shaped device a little larger thana Zippo lighter mounted on the right hand side of the engine compartment near the fuses with 3 wires (brown, white with red stripe and white with brown stripe). It grounds to the body of the car through the mounting screws, so if you DO have one, cleaning up those grounds would be where I'd start on troubleshooting.
It's also worth noting that you can bypass the solenoid completely and just touch a jumper cable from the battery to the starter. If it starts it's the wiring if not, check the ground strap first (and you can use the other jumper cable as a ground cable) - though in my experience a broken or missing ground cable has the starter move sluggishly rather than not at all.
well dont know why that one stopped. i mangage to make a working starter motor from 3 broken ones.
T BN2 Won't Start Austin Healey 18
K TR2/3/3A Have to always use a full choke to start the car? Triumph 19
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
J Spitfire No start after fiddling with dash Triumph 2
AHSebring How do I create "Contact" to "Start Conversation" in my About Tab? FORUM Navigation Questions 1
O Wedge 79 TR7 no start Triumph 5
J MGB 1966 MGB won't start MG 1
K TR2/3/3A Sluggish cranking on start up? Triumph 5
L T-Series Hard to start MG 11
mctriumph General TR NEVER start a car with stale gas Triumph 0
K TR2/3/3A Timing chain rattle on start up? Triumph 2
KVH General Tech Initial Start Up After Rebuild Triumph 23
B Healey Won't Start - No Spark Austin Healey 38
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
G Pre-War how to start a 55 mgtf. MG 3
KVH TR4/4A Hard Start When Engine Hot Triumph 20
K TR4/4A TR4 no start Triumph 26
E MGB MG Idle issues, restart issues solved. MG 4
M Spridget wont start Spridgets 50
D TR2/3/3A Getting difficult to start. Triumph 6
K TR2/3/3A Motor knocking at start up? Triumph 11
Q TR2/3/3A Where to start?! Triumph 13
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
dougie Bruce McLaren's start in an Austin Healey Austin Healey 0
K TR2/3/3A Hard start questions.... Triumph 4
pairof75's General TR Circulate fluids without engine start Triumph 10
S TR2/3/3A Will Not Start Triumph 52
R TR2/3/3A Re-start after total restoration Triumph 22
S General MG 77 MG no start MG 31
B Cold Start Problems BN7 Austin Healey 21
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T 100-6 start up issues Austin Healey 6
tr6nitjulius General TR AutoX & Rallye Start TRIUMPHest 2019 Triumph 0
K TR2/3/3A Mystery stall and no start? Triumph 7
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
tr6nitjulius New Official Start Great Race 6/22/19 Video Other Cars 0
tr6nitjulius Great Race 2019 Official Start 6/22/19 pics Other Cars 2
I General TR TR6 won’t start, no lights Triumph 12
RAC68 Healey Will Not Start Austin Healey 5
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
J TR6 Wont Start Triumph 10
Sarastro TR4/4A Another milestone: first engine start Triumph 8
HighAltitudeTR3 TR2/3/3A Doesn’t want to start up again after a ride... Triumph 24
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
Gerry M TR6 TR6 Won't Start Just Clicks Triumph 17
G Failure on Initial Engine Start After Rebuild Austin Healey 176
M Cold start problems Austin Healey 33
D Lily Engine first start Austin Healey 9
