    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
T-Series MGTF Xpeg Ignition Coil
Found out that the "Lucas" coil for the T series is recessed so low that the coil wire won't make contact without putting in a filler, I used a stiff spring. The threads aren't cut deep enough, naturally! What else is new! But it does work fine after the modification. Looks like the original, hope it holds up. :encouragement:
As long as the spring wire diameter is thick enough it doesn't turn into a "filament" it should be fine.
No it's not a fine spring Doc, I had to keep trimming it and bending one end to make 80/90 degree contact on both ends, pretty stiff in fact.
PAUL161 T-Series MGTF Ignition Key MG 7
PAUL161 T-Series MGA pressure plate verses MGTF pressure plate? MG 6
PAUL161 T-Series Rare 1954/55 MGTF Accessory MG 23
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
G Pre-War how to start a 55 mgtf. MG 3
G T-Series 1955 mgtf 1500 lites MG 5
PAUL161 T-Series Original 1955 MGTF Photos MG 6
PAUL161 T-Series $68,995.00 MGTF MG 5
mgbmedic T-Series Return to Forum / MGTF Restoration MG 6
JPSmit Mgtf Spotted 1
C T-Series Stuck exhaust valve on 54 MGTF MG 10
C T-Series 1954 MGTF [not the new TF] gearbox MG 4
AN5Sprite T-Series Considering an MGTF, how much $$$ MG 20
F T-Series Looking at a 1955 MGTF today- what's important? MG 8
Magyar T-Series MGTF Windshield MG 6
Magyar T-Series MGTF Dark Red Engine Paint MG 7
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
PAUL161 T-Series Victor MGTF [Sebarnes] MG 0
S T-Series Victor MGTF MG 17
CCURTISS T-Series MGTF Lower A-Arm Busing Replacement MG 1
CCURTISS T-Series MGTF 1500 Cooling Fluid Leak MG 6
CCURTISS T-Series Moss 5 Speed in MGTF Complete!!! MG 2
CCURTISS T-Series MGTF Firewall [what goes in what hole] MG 2
CCURTISS T-Series MGTF Carburetor Size MG 1
CCURTISS T-Series MGTF Flywheel and Pressure Plate Torque??? MG 2
CCURTISS T-Series MGTF 5 Speed Conversion MG 3
CCURTISS T-Series MGTF Shifter Rattle??? MG 4
C T-Series Nanjing MGTF MG 15
drjimwbrown T-Series Wonderful drive in MGTF down the Jersey Shore MG 5
swift6 T-Series Fun Hot Rod MGTF... MG 4
Bret T-Series Sighting MGTF in San Diego CA. MG 3
B T-Series MGTF "Upgrades" MG 11
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
PAUL161 Question for Hap and Others. 140 hp XPEG? MG 1
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 10
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
