TR4/4A I need a TR4A wiring diagram
ducatista
Can anyone help please?
My car is a 1967 model LHD with overdrive.
It's probably in the service manual, if only I had one...
A scan would do the job.
Hopefully.
Thanks in advance
Thanks Tinster,
It did help.
Weather's absolutely crazy for this time of the year.
Normally it is skiing season but I went to the beach to swim last weekend.
Temp around 20-25C and the sea a cool 16C
No snow even on the highest peaks.
I'm not complaining, I like a warm winter but it is kinda frightening isnt it?
Hey youre from PR?
I guess its always hot over there so swimming in the winter must be normal to you.
Thanks again
The Ducatista
Ducastista:
Yes, it is winter and much too cold for
swimming with water temps only about 78*F /23*C.
The tourists go swimming in that icy cold water
but we locals like the water 85/30 in summer.
Our temps are 78/26 in winter and 92/33 summer.
A narrow range.
Dale
Ha ha
I see your predicament Tinster, 23*C is kinda cold if its 33*C outside...!
I guess if the planet keeps warming up, we'll get to see such winters here in Greece too.
As for summer temps, 33*C is cool, here we get up to 38-42 on hot days. And thats HOT.
Riding my bike in such heat is torture, not to speak of the TR which gives your legs a good roasting through the GB tunnel.
These cars were not made for such conditions.
Yup,
Our "winter" is when we drive with our tops down
or off completely. Too hot in summer, so we have
the car A/C running full blast.
I figure another 4 to 6 months before I get the
Crypt Car clutch and rear brakes to a stage where
it is repaired enough to drive.
That will be the middle of summer and too hot
to drive the TR. So I am probably looking at
ten months before I can drive the TR .
regards,
dale
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
M TR4/4A 67 TR4A, need brake line fitting specs Triumph 6
M TR4/4A Need help with TR4A brakes Triumph 10
M TR4/4A TR4A - need windshield capping strip Triumph 2
P TR4/4A Need help with TR4A bonnet/hood mount problem, thanks! Triumph 4
M TR4/4A TR4A - need a windscreen frame vinyl trim kit Triumph 11
T TR4/4A TR4A - A Type OD Solenoid - need a bit of help Triumph 7
bcliff TR4/4A Triumph TR4A IRS FS. Need help with this one.PICS! Triumph 6
Stinger TR4/4A Need TR4A Camshaft Bearing Setscrew Help Triumph 5
Stinger TR4/4A Need a TR4A Cap for Valve Cover Triumph 3
A TR4/4A TR4A mixture problem - need advice please Triumph 41
K TR4/4A Clutch Replacement on TR4A. need advice Triumph 11
Y MGB Do I need a heater valve? MG 1
V Wanted What cars used this trunk latch? I need one! Other British Classifieds 2
AngliaGT '97 Miata - Need to Replace the EGR valve - recommendations? Other Cars 7
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 4
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
