TR6 How do you guys fold the top??
TomChar
I would think this was obvious, but it's not to me. My big concern is protecting the clear side windows, especially at the corners by the back window.
I unzip the rear window and lay it against the back valance panel, then unsnap the top from the bows and let that lie flat on the deck as the top bows fold down. This is where it gets iffy. I can either fold the corner windows over onto the top, then fold the top over the bows, or fold the top over the bows and then tuck in the windows. The second way actually lets me re-snap the windows to the body, and puts a nice gentle curve in the plastic. This seems to protect the corners the most for me, but obviously I can't use a cover.
Just wondering if there's a method I'm not seeing here. The car came with a few small tears, and those corners are torn out already, but I want to save it as much as I can. It's by no means ever going to be a show car, it's a daily driver actually, and the top doesn't look too bad or leak in regular rain while driving, and is garaged otherwise.
Just looking for ideas.
Cheers,
Tom
Tom, do you have the owners manual?
That is going to a lot of trouble. Unsnap the sides, pull the top handles and push it down and fold in the corners. Done, now put the cover on.
If the window is of concern, use a soft towel on the outward side as you fold it down.
Wayne
Start with this
https://youtu.be/IS2FhnWK6_o
I also have a couple of towels that place strategically around and over the windows before putting the top cover on.
Cheers
Tush
In addition to protecting the vinyl windows, I place two foam pieces that I keep in the trunk over each rear wheel well. It prevents the metal frame from damaging the wheel well covers.
A "TR6 Top Folding" video... gee, how easy a search would that have been. Except for the color, that's my car, even the wheels.
I do have the original owners manual, but the cover's so brittle I haven't opened it and it's been sitting on a bookshelf so long I forgot all about it!
Thanks everyone.
Isn't there a supposed to be bump stop or buffer that protects the vynil on the inner wheel arches?
As far as the top I tend to fold the windows and leave them on top, but I have experimented with tucking them in. It didn't seem to make much difference, but I don't stress to much over what I consider normal wear and tear.
On another note on the top, from distant memory that the 4A top tucked into the boot neater and also took up less space there. Since I spend most of my time driving with the top down I have considered fitting a TR4A frame (I have a spare) and top (would have to buy) to save a little weight and have more room in the boot with the top up.
I
..... On another note on the top, from distant memory that the 4A top tucked into the boot neater and also took up less space there. Since I spend most of my time driving with the top down I have considered fitting a TR4A frame (I have a spare) and top (would have to buy) to save a little weight and have more room in the boot with the top up.
You're throwing me for a bit of a loop here. Are you talking about a folding top that goes into the rear shelf area behind the seats where the optional "occasional rear seats" could be placed or a separable hood/top and frame that is removed and stored in the boot/trunk when not erected?
It's been a while since I have had a TR4A so I am going off of some potentially fuzzy memories. If you are talking about the later TR4A type folding hood/top that was stowed in the rear shelf area, I don't recall it being much if any smaller than that used by the TR5/TR250/TR6. Something else to consider, IIRC the windscreen frame and header rail latches are different between the TR4A and the later TR5/TR250/TR6. If that memory is correct, you would also need to use a TR4 or TR4A windscreen frame to use a TR4A hood/top.
I am talking about the folding top, the TR4a and TR250-6 are similar, but the later cars have hardware for the sides to seal with velcro above the side windows. The 4A doesn't, it has been a while for me too, but I think all the additional hardware takes up a little more space with the top folded. My memory is an 8 pack pop cooler would fit pretty easy behind the seats with the boot cover on with a 4A, and it can be done, but is a pretty tight fit with the TR250.
I started wondering if the difference might be in the seats. I looked at some 4A seats that I have and am not seeing where the seat backs are appreciably thinner than those on a 250 or a 6, they look about the same as a 250 and early 6, slightly thicker than 73 and up 6. At this point I have to conclude that if there was more room back there, it has to be due to differences in the folded top dimensions between the 4A and the later cars.
When I fold mine, I unsnap all the way around the sides, then unlatch and lift the front. As it starts to fold, I pull the top material out and lay it on the back deck as the frame folds up completely. I fold the top over the frame, and then I fold the side windows over the top. Haven't had any trouble with the windows scratching. I don't zip the rear window out at all.
Perry
Perry
Thats the right way to do it Perry
I lay a towel on top of the rear window before folding the sides in to avoid scratching of the clear Panels
Graze
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
L Continue to seek out the advice of you experienced guys Austin Healey 8
M TR2/3/3A Where have you guys put your stereos and speakers? Triumph 3
Keoke Hey Use guys Austin Healey 1
Trevor Jessie Any of you Spridget guys coming to MG2016 in June? Spridgets 3
M Off Topic Any guys on here live near Pittsburgh Airport. Triumph 1
T TR4/4A Okay guys-so how hard is it really to freshen up a TR4 engine? Triumph 31
T Okay guys-how crazy is this British Motor Corp 22
Gliderman8 TR6 Did one of you guys lose this? Triumph 10
HealeyRick How Many Big Healey Guys are Spridget Guys? Austin Healey 23
bugedd Looks like you guys are stuck with me Spridgets 10
anarchy99 Any Virginia Beach Spridget guys? Spridgets 6
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
SwamperCa MGC Cee Guys MG 12
B Anyone ever buy from these guys? any feedback? http://www.northwestimportparts.com Spridgets 6
B long time no post..got some free stuff for you guys Spridgets 0
Basil So you Healey guys want to rule the world? Austin Healey 6
Rut Lucky CA guys! Spridgets 2
ShawnC_at_Moss Question for you Bugeye guys regarding trunk side panels Spridgets 20
J One of you guys had great pictures of front apron Triumph 20
A TR7 SU Conversion- Request to the MG Guys MG 4
RichBall For us 1500 guys, high compression head up on Ebay Spridgets 10
T OK guys - what would you do in this situation Triumph 23
G Where you 6 guys putting fuel pumps? Triumph 10
tri_carb_healey A tribute to the TR guys Triumph 16
apbos TR2/3/3A Ok you mid-west guys here is a $100 TR3 Triumph 3
J Do any of you guys know.... Restoration & Tools 3
T OK guys - explain me this.... Triumph 12
frankenstang57 What do you guys think of the Sammio? Triumph 30
T OK guys - pick this one apart... Triumph 27
T TR2/3/3A One of you guys must save this TR2 Triumph 35
T Hi guys - can you help establish a date range? Triumph 2
T OK guys - I didn't buy the Quattroporte but... Triumph 29
A MGA hey guys picked up a 60 mga on craigslist MG 20
W I wasn't aware of these guys... Spridgets 1
Frankenhealey Any Bonneville guys here? Austin Healey 0
G What do you guys think? Spridgets 11
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
T Why don't you guys tell me this stuff ;-] Triumph 10
Robert560 Speaking of dowel bolts - Healey 5 Speed guys.... Austin Healey 5
B Seattle Guys- Free Midget body Spridgets 8
B Are my post helpfull for you guys? Restoration & Tools 7
N hi guys! Triumph 26
HealeyPassion Question for 5 speed conversion guys Austin Healey 13
UmmYeahOk So you guys want pics huh? Triumph 27
T Hap - some TR guys need rims from you Spridgets 1
T Happy New Year guys Spridgets 13
YankeeTR You guys might enjoy this... MG 16
