OK guys - what would you do in this situation
tdskip
Say, oh, you had a '67 TR4a in the garage. And just for conversations sake suppose it had all original paint. Assume that paint was super nice on the driver side but marginal on the passenger side (which is odd, yes). Now consider the hood - stripped to bare metal since it had too much surface rust to save the paint. Assume that you cannot swing getting the whole car painted, and paint matching the hood will be an iffy proposition. Lastly, figure that getting some sort of paint on the hood is the last item to do before putting back into service for a long time.
How would you approach this?
TR3driver
Great Pumpkin - R.I.P
My approach would be to drive it down to One Day Paint & Auto Body and have them paint the whole thing. They are a (probably local to SoCA) chain that does fair work at a cheap price. Not quite as cheap as Earl Scheib, but so far all their paint jobs have lasted well for me. And there is an ad in today's paper for a $400 (IIRC) paint job.
But if you really can't afford that, paint the hood to match the good side as close as you can. Doesn't really matter, it isn't going to look good anyway.
Or, you could go the "rusto-rod" approach and just leave the hood in primer (plus maybe a clear coat for rust resistance). It was almost the style around here for awhile : $10,000 paint job with one fender in primer.
Brosky
The advantage here Tom, is that people can only look at one side at a time. If you paint the hood as good as possible, you can only see the hood from one side of the car or the other to compare it to the side. If you look at it head on, the sides are not in view.
So I agree with Randall and then just drive it until you can.
And while doing so........
Look up the local Vo-Tech schools and go offer it up as a project car for their body programs. You might get lucky and get a complete, great job for the price of materials.
Geo Hahn
The budget paint places can vary quite a bit -- for example there are 2 Maacos in our town -- one does the so-so paint job you might expect, the other has turned out some great work on local British cars.
If you do the prep and get some locval references you may find you can afford a decent result.
mrv8q
Would you consider a flat black for the hood?
T
tdskip
I have access to a booth actually, and am itching to paint something you can see rather than suspension parts. Given that until the whole thing is a bare metal paint job it will look iffy at best, probably best to just keep cost down now and match it as best it can be done and drive her.
apbos
How about match the hood as best you can. If you do not have a perfect match use a vinyl stripe or numbers to break up the visual field and help "hide" the difference.
hondo402000
have a sanding party, a keg. lots of 400 grit wet sand paper and friends, and wet sand the whole car, you can tape it off and spray a 2 part epoxy primer, wet sand the bug out and then take it to the local elcheapo paint shop
Hondo
M_Pied_Lourd
Bring her up Tom. I am looking for a practice project before I paint mine :smile:
Cheers,
Tush
glemon
So the budget is limited, the question is what would I do, if I wanted someone to do it for me I would check the local craigslist or paper thrifty nickel or the like, there are usually guys who have worked in body shops in the past and now do work on the side and will work for reasonable and work with you on what you want done, talk to a couple of them, see what they can do for you within your budget.
If going DIY, which it sounds like you are interested in doing, and you want to just paint the hood, take a panel to the local auto paint store and have them match the paint as best they can, and have it mixed up (and put in a spray can if you don't have access to a gun), sand and prime and paint and drive.
If you decide to paint more than the hood sounds like you might as well paint the whole thing, as mentioned you could take it to the local Maaco or equivalent, or if doing it yourself you might try autocolorlibrary. They have Triumph chips from the 60s, and you can buy half a gallon of paint, the catalysts, etc. for about half or less of what the local body shop charges for PPG and such.
From where you are at I would try to get a decent paint match for the hood, paint, drive and enjoy. The view over the hood of a 4 is one of the nicer ones in the world of cars, make it nice and shiny for that reason, although the flat black would be kind of cool.
cheseroo
I've seen it and would go the flat black route on the bonnet. If you try to paint match, it will look paint matched. I don't think you'll be happy with a nice pretty bonnet and chips over the rest of the car. I'd stick with the original paint on the rest of it and matte black the bonnet.
Man, I'm a sucker for Royal Blue on these cars.
Wasn't this the guy who told me to not paint my 250 with rust spots and all?
mtlman8
I would take the car to a local automotive paint supply house, let them match the color then for about 20 dollars a can you could shoot it yourself, without air, yet still wet sand and polish the paint.
T
tdskip
Yeah, but that is <span style="font-weight: bold"><span style="font-style: italic">your</span></span> car. Ha.
glemon
I almost changed the TR250 to Royal Blue, have always wanted TR4-250 that color, ended up sticking with the original read for both originality and convenience, but love that dark blue color. Greg
M_Pied_Lourd
Yes, I quite like the Royal Blue on the 250's :smile:
Cheers,
Tush
CJD
Hondo
I'm in...if the beer is supplied!
John
Oh, if you want paint that looks old quickly to match, just go with the Dupont baseline cheapo, one coat laquer. Used that stuff a few years ago...just a couple weeks in the sun and it already looks aged 10 years.
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
L Continue to seek out the advice of you experienced guys Austin Healey 8
M TR2/3/3A Where have you guys put your stereos and speakers? Triumph 3
TomChar TR6 How do you guys fold the top?? Triumph 10
Keoke Hey Use guys Austin Healey 1
Trevor Jessie Any of you Spridget guys coming to MG2016 in June? Spridgets 3
M Off Topic Any guys on here live near Pittsburgh Airport. Triumph 1
T TR4/4A Okay guys-so how hard is it really to freshen up a TR4 engine? Triumph 31
T Okay guys-how crazy is this British Motor Corp 24
Gliderman8 TR6 Did one of you guys lose this? Triumph 10
HealeyRick How Many Big Healey Guys are Spridget Guys? Austin Healey 23
bugedd Looks like you guys are stuck with me Spridgets 10
anarchy99 Any Virginia Beach Spridget guys? Spridgets 6
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
SwamperCa MGC Cee Guys MG 12
B Anyone ever buy from these guys? any feedback? http://www.northwestimportparts.com Spridgets 6
B long time no post..got some free stuff for you guys Spridgets 0
Basil So you Healey guys want to rule the world? Austin Healey 6
Rut Lucky CA guys! Spridgets 2
ShawnC_at_Moss Question for you Bugeye guys regarding trunk side panels Spridgets 20
J One of you guys had great pictures of front apron Triumph 20
A TR7 SU Conversion- Request to the MG Guys MG 4
RichBall For us 1500 guys, high compression head up on Ebay Spridgets 10
G Where you 6 guys putting fuel pumps? Triumph 10
tri_carb_healey A tribute to the TR guys Triumph 16
apbos TR2/3/3A Ok you mid-west guys here is a $100 TR3 Triumph 3
J Do any of you guys know.... Restoration & Tools 3
T OK guys - explain me this.... Triumph 12
frankenstang57 What do you guys think of the Sammio? Triumph 30
T OK guys - pick this one apart... Triumph 27
T TR2/3/3A One of you guys must save this TR2 Triumph 35
T Hi guys - can you help establish a date range? Triumph 2
T OK guys - I didn't buy the Quattroporte but... Triumph 29
A MGA hey guys picked up a 60 mga on craigslist MG 20
W I wasn't aware of these guys... Spridgets 1
Frankenhealey Any Bonneville guys here? Austin Healey 0
G What do you guys think? Spridgets 11
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
T Why don't you guys tell me this stuff ;-] Triumph 10
Robert560 Speaking of dowel bolts - Healey 5 Speed guys.... Austin Healey 5
B Seattle Guys- Free Midget body Spridgets 8
B Are my post helpfull for you guys? Restoration & Tools 7
N hi guys! Triumph 26
HealeyPassion Question for 5 speed conversion guys Austin Healey 13
UmmYeahOk So you guys want pics huh? Triumph 27
T Hap - some TR guys need rims from you Spridgets 1
T Happy New Year guys Spridgets 13
YankeeTR You guys might enjoy this... MG 16
