TR6 Help with identifying my TR6 heads
Gliderman8
Over the weekend I had the opportunity to get two spare heads that a friend of mine wanted to get rid of.
Head #1 is the Original head that came with the car
Head #2 is a head he had on the car with hardened exhaust valves
When I got home I noticed that head #2 had a screw plug that head #1 did not.
I checked my TR6 and noticed that mine did not have this plug either.
Why is the plug there? Is it a later model? Can I use it on my '73 TR6?
Everything about the two heads looks identical except for the plug.
I did check my Bently manual and did not find anything... thanks for any help!
Hi Elliot,
I am going to take a guess....is that where an EGR valve would screw into? It is normal for that port to be plugged if the air pump and other emission stuff had been removed from the car.
Cheers,
M. Pied Lourd
Thanks guys... it makes perfect sense now that you point it out. I can sleep better tonight
V Help with identifying morris eight Other British Cars 12
T Lotus 7 - help identifying parts Lotus 5
J MGB Need help identifying these parts MG 6
T Wedge TR7 engine, need help identifying part. Triumph 5
JimLaney HELP: Identifying Chasiss and Engines Spridgets 7
Desert Rat Help identifying a hardtop Spridgets 10
P TR2/3/3A Need Help Identifying These Seats Triumph 6
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
L RE: Requesting help with identifying suspected rear brake adjuster piece? Austin Healey 4
L Request help with identifying this AH 1960 3000 part. Austin Healey 1
AngliaGT Wedge Help Identifying TR7/8 Parts Triumph 8
S help with identifying fiberglass frontend Spridgets 27
J Need help identifying Lucas parts Other British Cars 10
CZ_Dave Help in Identifying this British Ford? Other Cars 11
J help identifying my transmission... Triumph 8
B Please help identifying top bows MG 5
S Need help identifying rims Other British Cars 11
angelfj1 TR2/3/3A TR3A help identifying part Triumph 6
angelfj1 TR2/3/3A TR3A - help identifying part Triumph 9
Morris Help identifying carb set... Spridgets 18
C help identifying hard top Spridgets 1
angelfj1 TR2/3/3A Help identifying part [TR3A] Triumph 5
vping Need help Identifying an OD Transmission MG 3
A Help needed - identifying cylinder head castings Austin Healey 0
Monark192 Help identifying Carbs MG 2
vping Help identifying this odd part MG 11
T Need Help Identifying Parts MG 5
S Greetings! and help identifying this engine?. Sunbeam (Rootes) 14
Mickey Richaud Help with Identifying this TR Triumph 6
T Help identifying part Spridgets 16
MGTF1250Dave Help Identifying Distributor Triumph 3
tr6web TR6 TR6 Manifold gasket help Triumph 0
D TR2/3/3A Please help w this tuneup Triumph 19
D Help with what 4 numbers on MGC VIN mean MG 10
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
