Need help identifying rims
sidmabb
I was cleaning out the shed and came across 3 old rims. Im pretty sure they are british but that is where it ends. I believe they are 13's They are 4 bolt with 3-3/4 bolt pattern. 2 of them measure 3-1/2 between the beads and the other 4-1/2. Some one wrote 307401 on the 2 narrow ones. There are 3 pictures each in my photobucket album. They are not in order but they are numbered 1A 1B 2A and so on . ie 1 being the 1st rim and A being 1st picture of that rim.
More & Larger pictures here. Photobucket pictures
JPSmit
sprites and midgets are 4X4 inch 13 inch rims. They look kind of like early sprite rims.
Darwin
Bronze
3-3/4 would mark them as being from a spitfire, GT6, or some of the Lotus cars. There may be others as well.
AngliaGT
The Lotus rims had holes all the way around towards the outside.
- Doug
Platinum
In th' shape of the Lotus badge. Triangular. With th' "point" toward th' hub.
Platinum
'smits took th' camera so I can't post Lotus steel rim shapes.
But that ain't it.
S
sidmabb
I remember a few years back before I got the building there was a TR2 or 2 Maybe a TR3, Some old Austin sedans and a I think a GT6. There was several others before the city came in and cleaned it up. The ole boy who had a business there was a triumph lover but repaired them all.
Andrew Mace
The 3.5" wheels are probably mid-1960s Triumph Herald. Although they would interchange with Spitfire (which also used 3.5" wheels until the 1970 model year), Spitfires usually had wider slots, as did Heralds until maybe 1963 or so. The 4.5" wheel, which I'll assume has "LP875" stamped on one of the "stiffeners between lug holes, would be a Dunlop-made wheel from a pre-1971 GT6 or a 1970-only Spitfire.
Oh, and the "S-in-a-diamond" logo in the picture above signifies that it's a Sankey wheel, the alternate supplier of wheels to Triumph (Dunlop, maker of the aforementioned LP875 among other wheels) being the other supplier.
Hope that helps!
S
sidmabb
Thanks a bunch
I will list the narrow ones as early 70's Triumph and the Wide one as 60's/early 70's Triumph. By the way I had a Harold in the late 70's. It was Blue and ran like a top. I remember taking a corner to fast and the back end would whip around and give you a heart attack but it always seemed to end up going where it was pointed. I also remember the front wheels would turn almost 90 degrees. I cut the wheather stripping so the top would come off. Had no title so I put the plates off my Datsun 1200 on it. Had a single Solex (I think) when I bought it but I put a couple S.U's on it. I cant remember what I got the off of but they were a pretty easy conversion. I worked at an import repair shop and there was a little shed out back full of British engines. Like a Dummy I traded the Harold for a boat
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
J MGB Need help identifying these parts MG 6
T Wedge TR7 engine, need help identifying part. Triumph 5
P TR2/3/3A Need Help Identifying These Seats Triumph 6
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
J Need help identifying Lucas parts Other British Cars 10
vping Need help Identifying an OD Transmission MG 3
T Need Help Identifying Parts MG 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
B TR2/3/3A Need help with tr3 project Triumph 9
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
Steve P. Need help with oil filters Spridgets 1
RickPA Need help installing steering idler oil seal Austin Healey 6
M TR4/4A Need help with TR4A brakes Triumph 10
