help identifying my transmission...
jwolff
Does anyone know what car this is from based off this serial number? I'm guessing it's from a TR4 or TR6 as it has the bent shifter but wasn't sure.
thanks!
TR3driver
Great Pumpkin - R.I.P
That's a casting number. The serial number, if present, will be stamped into one of the bosses where the clutch shaft goes through.
J
jwolff
Ah, thanks for that information! I'll get back with real serial number soon then.
J
jwolff
CT 31888
So it's from a TR4... thanks Randall and Andy.
One more question while I'm at it... someone recently told me that I can swap out the shift lever with one from a TR3, can someone verify that? I've put up a want ad for a shift lever already in the wanted section.
thanks again
TR3driver
It can definitely be done. However you may need to modify the top cover slightly by drilling the threads to clear the bolt that goes through the shift lever. I don't recall the change points offhand, but the later levers using locating pins instead of the through bolt.
Note that there will also be some other issues if you are putting it in your 56 TR3. The 4-synchro box is about 3/8" longer than the 3-synchro, which means the rear mount needs to move back. And most likely your gearbox tunnel won't clear the starter bulge on the gearbox unless you massage it a bit or use a tunnel from a later TR3A.
TR3driver
Another route if you are interested is to rebuild a TR3 top cover using the shift rails & forks from the TR4 cover. That way you get to keep the dipstick, which I find kind of handy.
J
jwolff
Thanks Randall, the TR4 gearbox with overdrive came already installed in my car and everything fits fine so I guess a previous owner took care of any adjustments.
vping Need help Identifying an OD Transmission MG 3
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
V Help with identifying morris eight Other British Cars 12
T Lotus 7 - help identifying parts Lotus 5
J MGB Need help identifying these parts MG 6
T Wedge TR7 engine, need help identifying part. Triumph 5
JimLaney HELP: Identifying Chasiss and Engines Spridgets 7
Desert Rat Help identifying a hardtop Spridgets 10
P TR2/3/3A Need Help Identifying These Seats Triumph 6
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
L RE: Requesting help with identifying suspected rear brake adjuster piece? Austin Healey 4
L Request help with identifying this AH 1960 3000 part. Austin Healey 1
AngliaGT Wedge Help Identifying TR7/8 Parts Triumph 8
S help with identifying fiberglass frontend Spridgets 27
J Need help identifying Lucas parts Other British Cars 10
CZ_Dave Help in Identifying this British Ford? Other Cars 11
B Please help identifying top bows MG 5
S Need help identifying rims Other British Cars 11
angelfj1 TR2/3/3A TR3A help identifying part Triumph 6
angelfj1 TR2/3/3A TR3A - help identifying part Triumph 9
Morris Help identifying carb set... Spridgets 18
C help identifying hard top Spridgets 1
Gliderman8 TR6 Help with identifying my TR6 heads Triumph 3
angelfj1 TR2/3/3A Help identifying part [TR3A] Triumph 5
A Help needed - identifying cylinder head castings Austin Healey 0
Monark192 Help identifying Carbs MG 2
vping Help identifying this odd part MG 11
T Need Help Identifying Parts MG 5
S Greetings! and help identifying this engine?. Sunbeam (Rootes) 14
Mickey Richaud Help with Identifying this TR Triumph 6
T Help identifying part Spridgets 16
MGTF1250Dave Help Identifying Distributor Triumph 3
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
