Heater box
vping
Bronze
I have heard Janel speak of wrestling with this. I have all the bolts removed (I think) but I can't see to wrastle this one out.
Any tips?
Have you gotten thecables to the controls loosened yet? There's one short one you have to remove from the control in the dash/console to pull the heater box out.
So the cables come out with the box?
1 does...the one for the heater control on the engine doesn't.
What's odd is that there is a cable running through the grommit right under the heater box in the engine bay. It is only thing I have found not connected & the only thing I cannot figure out where it goes. I'll look for a pic.
The cable I'm talking about exits the firewall behind the radio console & goes directly to the heater box; but you can't see it on the engine side. You may be seeing the speedo cable as some cars with angle drives had them coming out on the passenger side of the firewall just below where the oil line exits.
Or, it could be the cable going to the heater control valve.
Viping, You might be able to see the cable Tony is talking about by sliding under the passenger side, (fun,fun,fun), and taking off the heater air deflector and looking inside the hole with a flashlight. Not too bad if the right seat is out. As Tony said, the cable does not come through the firewall. It works the heat / defroster flapper on the bottom of the heat box. Also after you get that cable disconnected, the rubber seal between the heat box and the body may be fused to the body from age. Mine was fried! /ubbthreads/images/graemlins/rolleyes.gif PJ
If the 'cable' you're talking about is the one I'm seeing, its the temperature senson...do you have a combo guage?
LoL, must not be important.
That ~should~ be the heater control valve cable:
Yup. Should be a "Rube Goldberg" lookin' thing (see previous photo) there to control hot water flow. You've got "constant flow" of heat without it. They used to be VERY expensive. I even went to the trouble of making a mold for the rubber diaphragms in them years ago.
Shucks another non-original part! /ubbthreads/images/graemlins/devilgrin.gif
Let me go check Moss.
Moss 360-410. I gotta see if maybe the midget has the same part. Actaully I remember now. It does not. It's a valve on the block that you turn by hand.
Argh! I need another part now.
For the time being you can route a hose back around to the other tube running down the carb side. No "downtime". I keep a blanking plate and shorter bolts on-board to shunt the port in case the valve develops a leak on a trip, too. /ubbthreads/images/graemlins/wink.gif
I can run fine the way I have it now but i'll be running heat all the time. I'll see how it goes. Least of the worries now. Going out to work on the other caliper rebuild & rotor cleanup.
Did you ever get the heat box out?? Find the cable end?? /ubbthreads/images/graemlins/yesnod.gif /ubbthreads/images/graemlins/nonod.gif PJ
I have been working on the brakes,
https://pg.photos.yahoo.com/ph/jvping/alb...m/ph//my_photos
but had posted the question so I can get working on it. There is no real reason to take it out but I want to make sure it is in working order and not going to crap out on me. I am going to add new brake & clutch MC lines so I might as well take it out & paint it while I am there.
R TR6 Heater box Triumph 6
Healey Nut Heater Box Installation Austin Healey 4
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
R Heater box assembly assistance Austin Healey 16
Jim_Gruber Heater Box and Insulation for Bugsy IV Spridgets 8
C Help me identify this Heater Box, Please Austin Healey 7
Rut TR4/4A Heater box Triumph 1
C Value of 100-4 heater box?? Austin Healey 2
Boggsy64 MGB Heater / Air box drain MG 21
Lynn Kirkpatrick MGB Heater Box Removal MG 8
B Up-date on heater box refurbishment Austin Healey 0
B antifreeze ccming out heater box feed? Spridgets 4
D Smith's Heater Box - AH Spares Spridgets 9
I TR6 Si sealant for TR6 heater box? Triumph 1
UmmYeahOk Spitfire GT6/Spitfire Heater Box Mounting Triumph 12
H 1966 3000 BJ8 Heater Box Data Tag Data Info Austin Healey 1
69MGC MGB MGB Heater Box Removal MG 15
AUSMHLY Heater box - how does water get in it ? Austin Healey 32
jvandyke heater box plates Spridgets 3
Lin Cape international heater to replace Smith's Box Austin Healey 7
N Heater box removal MG 9
Steve1970 Getting the heater unit box out Triumph 16
I BE heater box questions Spridgets 7
S Heater Box Extracted! Spridgets 13
Mg_Bizzle Heater box MG 29
H Would anyone like a heater box? Spridgets 0
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
AUSMHLY Water is leaking into - out of heater box Austin Healey 13
Baz Heater box / cooling system Spridgets 8
TR674 Heater box painting Triumph 16
KLUTZ Opening the front of the heater box Q. MG 18
R heater box drain tube MG 3
jlaird Another darn heater box question Spridgets 6
John Loftus heater box mystery studs Austin Healey 31
A BJ8 Heater Box - Suggestions Austin Healey 2
Bill Redd Heater box fan Triumph 4
Bill Redd Heater Box Rebuild Triumph 10
CDK Heater box Grommets [Parts Find] Austin Healey 7
M TR6 TR6 heater box arm Triumph 4
Bill Redd TR6 TR6 heater box Triumph 5
I MGB 1980 mgb heater box MG 2
BierRunner TR6 Heater Valve Triumph 12
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
