heater box drain tube
Yup, best way is to lay under the car when its on stands, reach way up around the tranny, grab the end of it and pull the bulb off. Never plug up again and you'll never know the difference except your car won't get flooded when it rains. Seriously, the bulb is designed to catch dirt, plug up and make MG owners angry. One of the first things I do to every MGB I get is pull the bulb off.
When you crawl under the car to clean the drain, and you have to poke it with a rod or wire to break loose the dirt, make sure your face is out of the way. Now ask me how I know this! Hmmmm. /ubbthreads/images/graemlins/rolleyes.gif PJ
Just cleaned my bulb, then came back here to see if I did it right. Hmmm. Guess I'll just pull the bulb off after all. It was really full of what looked like AZ dirt.
Thanks for the warning, Paul. Because of you I used a full-face mask and saved myself a faceful.
Guinn
Boggsy64 MGB Heater / Air box drain MG 21
R TR6 Heater box Triumph 6
Healey Nut Heater Box Installation Austin Healey 4
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
R Heater box assembly assistance Austin Healey 16
Jim_Gruber Heater Box and Insulation for Bugsy IV Spridgets 8
C Help me identify this Heater Box, Please Austin Healey 7
Rut TR4/4A Heater box Triumph 1
C Value of 100-4 heater box?? Austin Healey 2
Lynn Kirkpatrick MGB Heater Box Removal MG 8
B Up-date on heater box refurbishment Austin Healey 0
B antifreeze ccming out heater box feed? Spridgets 4
D Smith's Heater Box - AH Spares Spridgets 9
I TR6 Si sealant for TR6 heater box? Triumph 1
UmmYeahOk Spitfire GT6/Spitfire Heater Box Mounting Triumph 12
H 1966 3000 BJ8 Heater Box Data Tag Data Info Austin Healey 1
69MGC MGB MGB Heater Box Removal MG 15
AUSMHLY Heater box - how does water get in it ? Austin Healey 32
jvandyke heater box plates Spridgets 3
Lin Cape international heater to replace Smith's Box Austin Healey 7
N Heater box removal MG 9
Steve1970 Getting the heater unit box out Triumph 16
I BE heater box questions Spridgets 7
S Heater Box Extracted! Spridgets 13
Mg_Bizzle Heater box MG 29
H Would anyone like a heater box? Spridgets 0
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
AUSMHLY Water is leaking into - out of heater box Austin Healey 13
Baz Heater box / cooling system Spridgets 8
TR674 Heater box painting Triumph 16
KLUTZ Opening the front of the heater box Q. MG 18
vping Heater box MG 19
jlaird Another darn heater box question Spridgets 6
John Loftus heater box mystery studs Austin Healey 31
A BJ8 Heater Box - Suggestions Austin Healey 2
Bill Redd Heater box fan Triumph 4
Bill Redd Heater Box Rebuild Triumph 10
CDK Heater box Grommets [Parts Find] Austin Healey 7
M TR6 TR6 heater box arm Triumph 4
Bill Redd TR6 TR6 heater box Triumph 5
I MGB 1980 mgb heater box MG 2
BierRunner TR6 Heater Valve Triumph 12
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
