    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Heater box / cooling system
Baz
Getting the heater box out, there are two ports for coolant. The top one goes to the back end of the cylinder head, can find a blanking plate for that, no problem.
The bottom goes to a tube junction on the hose that runs from the water pump to the left side of the bottom crossover tube.
I've checked the usual sources for a hose that doesn't have this junction, and can't find. I don't want to screw / bolt it closed because I'm not sure what the pressure will be like.
Q1. For those that have the heater box removed, what hose did you use and is it something I can get at my local parts store?
Q2. How much coolant should I subtract by not having the heater box and associated hoses?
Thanks! /ubbthreads/images/graemlins/smile.gif
Just put a bolt in the hose opening and put a clamp on it. Will be fine, not a lot of pressure in the coolent lines.
barry,
why are you removing the heater box? if you lived near jack i could see it.
Fred, a heater in a summer car is as much use as a chocolate teapot. Too much salt on Illinois roads for winter driving. I'll keep it handy so I can put it in for shows etc..
Bob, thanks, that's perfect, that's wahat I'll do.
gotta point there ... i'm not so quick to do the same since i figure i might be driving in the chill of fall on a clear day. thanks
do not put a blanking plate on the motor. route your hose to the return and leave the valve open. this helps cool the rear section of the block and head ( better circulation )
And that is a good point, in fact a very good point. Circulate that coolent.
Thanks Taz, will keep valve in-situ and by-pass direct to pump. Thanks all.
Be busy on this when the girls go to bed...
R TR6 Heater box Triumph 6
Healey Nut Heater Box Installation Austin Healey 4
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
R Heater box assembly assistance Austin Healey 16
Jim_Gruber Heater Box and Insulation for Bugsy IV Spridgets 8
C Help me identify this Heater Box, Please Austin Healey 7
Rut TR4/4A Heater box Triumph 1
C Value of 100-4 heater box?? Austin Healey 2
Boggsy64 MGB Heater / Air box drain MG 21
Lynn Kirkpatrick MGB Heater Box Removal MG 8
B Up-date on heater box refurbishment Austin Healey 0
B antifreeze ccming out heater box feed? Spridgets 4
D Smith's Heater Box - AH Spares Spridgets 9
I TR6 Si sealant for TR6 heater box? Triumph 1
UmmYeahOk Spitfire GT6/Spitfire Heater Box Mounting Triumph 12
H 1966 3000 BJ8 Heater Box Data Tag Data Info Austin Healey 1
69MGC MGB MGB Heater Box Removal MG 15
AUSMHLY Heater box - how does water get in it ? Austin Healey 32
jvandyke heater box plates Spridgets 3
Lin Cape international heater to replace Smith's Box Austin Healey 7
N Heater box removal MG 9
Steve1970 Getting the heater unit box out Triumph 16
I BE heater box questions Spridgets 7
S Heater Box Extracted! Spridgets 13
Mg_Bizzle Heater box MG 29
H Would anyone like a heater box? Spridgets 0
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
AUSMHLY Water is leaking into - out of heater box Austin Healey 13
TR674 Heater box painting Triumph 16
KLUTZ Opening the front of the heater box Q. MG 18
vping Heater box MG 19
R heater box drain tube MG 3
jlaird Another darn heater box question Spridgets 6
John Loftus heater box mystery studs Austin Healey 31
A BJ8 Heater Box - Suggestions Austin Healey 2
Bill Redd Heater box fan Triumph 4
Bill Redd Heater Box Rebuild Triumph 10
CDK Heater box Grommets [Parts Find] Austin Healey 7
M TR6 TR6 heater box arm Triumph 4
Bill Redd TR6 TR6 heater box Triumph 5
I MGB 1980 mgb heater box MG 2
BierRunner TR6 Heater Valve Triumph 13
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
