RestoreThemAll
I took it apart just a few weeks ago. No before pictures were taken because "I'll remember how it goes back together":highly_amused: Has anyone had their heater box apart recently?
1) there was felt on top and bottom of the heater core inside the box. What are people using to replace the felt?
2) The water valve mounting adapter has a groove that fits just inside the box. I thought that it had an o ring to retain it then I ran across an aluminum ring. which one should be used to retain the valve in the box? See heater core pic.
3) There are four holes in the bottom panel and two in the front of the box that I believe had no purpose. Just had screws plugging them. Is that correct?
4) which way does the bottom panel go? See side bottom panel pic. Do those notches go to the back or from?
5) what is a good material to use to seal the heater box to the plenum box?
