Chilly said:
Any ideas on the flex fuel line from the hard line to the carbs ? I'd like to avoid standard rubber lines and go with a braided. It's a 66 3000.
Not sure I understand, but you shouldn't be using a rubber fuel line by the carbs. You should use the braided fuel line available at just about every Healey parts specialist. These lines were standard on BJ8's.
