TR2/3/3A Gear oil in the gear box?
joe kumpel
Dumb question..........my service manual says SAE 30 in the gear box.
Can this be correct? I thought gear oil in both differential and gear box.
Thanks
Motor oil was the official factory recommendation until about 1960 or so. There was even a service bulletin in 56 or 57, warning against using gear oil in overdrives (but saying it was probably OK in non-OD gearboxes).
I'm running 90w-140 synthetic in my non-overdrive box, and have no complaints. John Alan posted an interesting test last year. It showed that the 30w is about the thickest you want to use in an overdrive box. With more viscous oil the overdrive pump pressures go cosmic. So, when I rebuild the TR2 overdrive, it will get straight 30w.
Which of course is very strange, since the early factory recommendation was 50 weight in temperatures over 70F. They also delivered a whole bunch of A type ODs with 90 weight. So that test "shows" that the factory was delivering cars that would blow up instantly. Kind of silly to say that, after all these years when they obviously didn't blow up ...
Most likely, IMO, that OD had been modified with shims under the accumulator spring, causing the spring to reach coil bind before the relief ports were completely open. BTDT (but none of the articles seems to mention the possibility).
Adding greatly to the confusion is the fact that motor oil and gear oil are deliberately graded on different scales. 90 weight is actually thinner than 50 weight! (at the same temperature, of course, they all change viscosity wildly as the temperature changes).
From what I remember about the tests, the OD's didn't "blow-up", but rather had issues dropping out of overdrive when the pressures doubled the specs.
More likely getting stuck in overdrive. The extreme pressure forces the cone clutch harder into the cone. But in my case, the excess pressure did eventually "blow up" the OD. Among other things, it broke the snap ring that holds the clutch assembly to the carrier bearing.
You're right...the way I worded it was confusing. They would stick in overdrive if the pressure was to high. I've been flipping through the old posts, but can't seem to find the test Alan John posted. Maybe he'll chime in...
Check the Quantum Mechanics website. I'm pretty sure it's still up there.
I'll look, thanks!
And Marv has an interesting point...all gearboxes recommend non-detergent oil. Even boat transmissions recommend non-detergent. Why is that? Non-detergent is relatively hard to find.
John,
I found 30 wt non/d on the shelf at Auto Advance. I did buy a couple of extra quarts. I kinda remember something about non/d didn't attack the bronze bushing in the trans.
Marv
Well, not "all". Standard-Triumph never said "non-detergent", and actually recommended the same oil as for the engine (before they started recommending gear oil).
I've heard several theories as to "why". The one that makes the most sense to me is that the detergents are intended to help keep dirt (wear particles) suspended in the oil, where they can be removed by the filter. But in a gearbox without a pressure filtration system, it is better for the wear particles to settle to the bottom rather than getting splashed back onto the gear faces and bearings to increase wear.
If you do stick with motor oil, I suggest Valvoline Racing (the "Not Street Legal" stuff) in 20W50. It is a low detergent oil, but the high levels of ZDDP will help protect the weak spots in the TR2-6 gearbox, which is the counteshaft bearings and thrust washers. I used it for many years (based on advice from Ken Gillanders and Herman van den Akker) and it works well enough.
But Redline MT-90 (which is a GL4 gear oil as recommended later) will make it shift better.
Thanks to everyone for all the good info and insight. Since I'm running a non-overdrive gearbox I
think gear oil will be the choice.
Again, THANK YOU ALL
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Joe_Healey TR5/TR250 Overdrive Gear box oil Triumph 8
mrv8q TR2/3/3A Mixing MT-90 with Hypoid Gear Oil? Triumph 13
tinman58 Off Topic GL4-GL5 gear oil Triumph 6
S TR4/4A Trans/OD gear oil? Triumph 14
Rut GL4 gear oil Spridgets 3
R Gear reduction starter hits distributor oil line bolt Austin Healey 14
T Gear Oil Leak Austin Healey 17
Gerry M TR6 TR6 gear oil Triumph 8
A Proper Gear oil? Triumph 9
J Healey Gear Box & OD oil Racing 5
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
M correct gear oil for bj8 trans and overdrive ???? Austin Healey 5
rkep01 Cornhead grease vs hypoid gear oil Spridgets 6
KVH GL4 Gear Oil Triumph 5
rlich8 Gear Oil Triumph 9
toysrrus TR2/3/3A TR3 Gear Oil Recommendations Needed Triumph 6
J Rear Axle/Differential Gear Oil Spridgets 13
R SAE 90EP Hypoid gear oil MG 2
A Gear box oil MG 9
ekamm gear box oil Triumph 13
lbc_newbie Gear oil type for 210 4 speed tranny.... Spridgets 3
M Gear oil? Spridgets 4
dklawson Transmission Gear Oil - Synthetic? Triumph 7
W Silly question Gear Box oil change/top up MG 11
R Best gear oil for transmission in midget[snail] Spridgets 3
Shinsen774 Rear Diff Gear Oil Change Interval MG 2
OregonTR4A Adding gear oil to the gearbox? Triumph 8
LuckyLuke Right Oil for BN1 axle and gear box Austin Healey 4
R MG MIdget 1500 gear box oil changing MG 0
R MG MIdget 1500 gear box oil changing Spridgets 13
vping Rear Gear oil MG 1
A TR4/4A TR4 gear box oil Triumph 13
W MGB MGB GEAR BOX OIL. MG 7
tahoe healey gear box/ OD oil Austin Healey 6
G GL-4 vs GL-5 gear oil Restoration & Tools 6
BierRunner TR6 Gear Shift Knob Challenges Triumph 8
L T-Series Gear box servicing cap. MG 5
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
B Transmission Gear Lockouts Austin Healey 8
S Gear Shift Lever Travel Austin Healey 13
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
