Gasket sources
Looking for alternative sources for engine gaskets for my 3.9 litre Rover.
In particular, the valley gasket and pan gasket.
Open to any and all suggestions (other than "dealer").
:smile:
Steve
Platinum
It's originally a Buick engine, so I should think that the pan gasket at least would be identical. I'd suggest that a specialist in that vintage of American iron would be able to help?
HealeyBN7
Rick,
For my Land Rovers I have ordered from Island 4x4 in the UK. Even with the shipping cost the prices are great and the speed of delivery is also excellent.
Check this out for 109 pounds sterling. It is probably cheaper than just the valley gasket from the dealer:smile:
https://www.island-4x4.co.uk/camshaft-kit-v8-39-efi-p-1689.html
Cam kit which fits all Rover V8 3.9 EFI engines from 1989 to 1995.
Kit comes with:
You get the valley gasket and....
Camshaft
16 Followers Genuine
Timing chain
Crank gear
Cam gear
Front cover gasket
Waterpump gasket
Inlet manifold gasket with seals
2 Rocker cover gaskets
Dean
95 Range Rover
60 Healey BN7
70 Lotus
59 ??? (in negotiations)
88 M5
philman
I use gold coast rovers, one of our supporting vendors, in california. fair price and decent shipping charges.
LarryK
BritishPacific is a good aftermarket British Heritage vendor. I have used them for some Rover parts along with Gold Coast, Atlantic British and XKs Unlimited.
rovernut
<span style="font-weight: bold"> </span> <span style="font-size: 14pt"> </span> D <span style="font-size: 20pt"> </span> D&D Fabrications in Michigan........Everything you need for your Rover V8(Buick,Oldsmobile 215V8 )
rick_ingram
D&D built my stroker 3.9 litre. I'm just looking for any and all of my options.
:smile:
rovernut
There are many sources in Britain........Real Steel, RPI....to name a few that i've used, but there are hundreds more...........You would want composite head gaskets i would think but there are many options available for the rest
DNK
Compared to Steel??
LarryK
The new composite gaskets work very well. No sealant mess, just torque gauge to specs and done. Valley gaskets and rockers the same way and very clean and pretty leak proof. Easier to get apart later.
H Head Gasket Sources Austin Healey 14
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
B TR6 Gasket sealer Triumph 1
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Failed intake manifold gasket? Triumph 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
RJS TR4/4A Fuel Pump Gasket Triumph 8
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KVH General Tech Permatex Aviation Form a Gasket; Permatex Ultra Gray Triumph 12
P MGB Zenith water choke gasket needed MG 4
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
T TR2/3/3A tr3 head gasket Triumph 38
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
DrEntropy MGB Head gasket R&R goes on... MG 13
tahoe healey Cork Gasket Prep Austin Healey 17
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
LAW75 Timing Chain Cover Gasket Austin Healey 12
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
B Bonnet hinge gasket Spridgets 10
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
R BJ8 Cylinder Head Gasket Austin Healey 38
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
B TR4/4A Head gasket won't lay flat Triumph 13
T TR6 TR6 Carb Gasket Sealing Triumph 1
Michael Oritt Manifold Gasket Dressing/Sealant Recommendations Austin Healey 6
K Gearbox Throw-out pin and gasket question Austin Healey 8
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
D TR2/3/3A OD cover plate gasket sealer. Triumph 17
F Sump Gasket Question Austin Healey 15
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
F Heater valve/tap gasket- Install dry? Austin Healey 10
steveg Strange gasket pieces Austin Healey 5
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
