Figure 8 Gasket Info
KVH
Just for informational purposes, I reported that the copper gaskets in the gasket set from BPN are thicker than the steel gaskets.
I actually mic'd the steel ones from my car, and they are .001 less thick than the steel ones that came with my new piston liner kit (which, as stated, aren't as thick as my copper ones).
In addition to this, the steel ones from my car are corroded and broken.
This all makes me wonder why anyone would not simply insist on using the thicker copper gasket. I'd say the steel ones may have been leaking, and may also have contributed to combustion leaks since the liners were not proud of the block.
I'll now return to my chess game.
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
KVH General Tech Figure 8s Triumph 7
Hamish Racing TR2/3/3A Fast Road TR3a on figure of 8 sprint track - UK Triumph 10
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
2wrench TR6 Horny car just won't quit. On top of that, likes diesel. Go figure. Think mechanics Triumph 9
Jer when something doesnt make sense... and you finally figure out why ! Spridgets 4
P TR2/3/3A Figure 8 gaskets at bottom of liners Triumph 4
2billydavies TR2/3/3A question about Figure of 8 installation Triumph 9
S TR2/3/3A Figure 8 gaskets Triumph 17
F White smoke and I cant figure it out. Spridgets 17
bighealeysource Can't figure out why engine is missing on BN2 Austin Healey 6
B MGB Go figure! lucky day today! MG 3
K Figure of 8 Gaskets for Wet Liner Engine? Triumph 5
M can not figure out search FORUM Navigation Questions 1
KVH Revelation Re Those Figure 8 Sleeve Gaskets Triumph 8
KVH Figure 8 Gaskets Below the Sleeves Triumph 4
newmexTR3 How do you figure out a cam's valve clearance Triumph 2
regularman Still trying to figure this overheating thing out. Spridgets 35
Luke_Healey How do I figure out what kind of brake fluid? Spridgets 24
PATR8 Wedge TRy to figure this TR7 out Triumph 10
jdubois Ok, the Triumph guys couldn't figure this out... MG 17
regularman This here is what I figure I am going to do Spridgets 12
Rob_P Trying to figure out wgich carpet piece goes where MG 7
KVH Those Figure 8 Gaskets Triumph 1
jaybird Figure this one out please! Disappearing gasoline MG 37
M If I could just figure a way...... Austin Healey 2
tr6web TR6 TR6 Manifold gasket help Triumph 0
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
B TR6 Gasket sealer Triumph 1
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Failed intake manifold gasket? Triumph 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
RJS TR4/4A Fuel Pump Gasket Triumph 8
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KVH General Tech Permatex Aviation Form a Gasket; Permatex Ultra Gray Triumph 12
P MGB Zenith water choke gasket needed MG 4
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
