TR6 Engine Will Not Shut-Down
SherpaPilot
There is most likely a simple explanation as to why this has happened but I am wondering if this has ever happened to anyone else. Recently my TR6 showed excessive charge rates. I had the alternator checked and the report card indicated it was OK. The car was parked for one week while I left the area for business. Upon my return, the battery was completely dead and would not take a charge. I assumed I had a bad cell or two which had contributed to the excessive charging rate previously experienced. I replaced the battery with a new one. I also checked the car for any parasite voltage that may have caused the battery to run down during my absence. The passive voltage was measured at 3.5 milliamps which according to various sources is about normal for a car with a clock which I have in my after-market radio. This is a stock engine with an electronic ignition system in place of the points which I have had for several years.
Tonight I drove the car on a 30 minute run down some back roads just to check the charging rate and to get my Triumph fix for the night. Upon my return to the garage, the car would not shut-down. It continued to run as if the key was still on. I pulled the keys from the ignition switch but the engine continued to run. This is not the common dieseling problem but more of an ignition refusing to shut off problem. I had to pull the coil wire from the distributer to kill the engine. I then disengaged the battery from the car.
My first thought is the ignition switch has failed. Could there be another problem area I need to investigate?
SherpaPilot
SherpaPilot
Thanks for the link. I'm on my way to the garage now to trouble-shoot the problem. The link described my situation exactly.
SherpaPilot
SherpaPilot
Problem resolved. Some idiot (that would be me) incorrectly connected the fuse wiring. I went back to the manual and duplicated each wire going into/out of the fuse box. That fixed the problem.. Thanks for the link. Drove the car tonight without any problem.
B Engine Dieseling a Bit at Shut Down Austin Healey 12
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
