TR2/3/3A Engine stalling and backfiring
R
Redoakboo
I have just finished a total restoration of my 54 TR-2. I went to a car show last weekend and the engine backfired and stalled several times. I made it to the show. On the way home I drove about two blocks and the engine quit all together. I cranked for awhile and got it running and out of the intersection. It died again and would not start. I had to call AAA for a tow. The plugs looked good, I could see no leaks around the carbs. While trying to restart it the choke cable became disconnected.Good oil pressure 50-60 when started. Dropped when it got warm to about 20. I have not checked the timing recently, ran good when I first drove it; could have slipped? No smoke out the back when starting?
Dick
NutmegCT
Did the engine start normally when you first left for the car show? Then the problems began during the drive?
One thing to check: did the distributor come loose in its mount? If the distributor itself rotates, that would totally screw up the timing.
Tom M.
LarryK
Backfire out carbs, too lean, backfire out back. Timing might be off. Check distributer as mentioned.
LarryK
Recheck and clean points, bad condensor will fry points.
NutmegCT
Dick - you started the topic with "I have just finished a total restoration of my 54 TR-2."
What parts of the ignition system did you replace?
What parts of the fuel system did you replace?
Did the stalling and backfiring problem pop up when you first started and ran the engine after the restoration? Or only when you made the drive to the car show?
Thanks.
Tom M.
CJD
Definitely not the 68 year old condenser, LOL! It's actually been a while since the restoration... just based on his previous posts he has some miles on the car. Funny...I finished my restoration almost 6 years ago now, although it still seems like I "just finished". In reality, my car would be considered "old" now, based on time since the restoration was finished...?!?
R
Redoakboo
Thanks.
Tom M.
I only replaced the points, plugs and most wires. I rebuilt the SU's, new fuel pump. I drove the car about 40 miles to a car club breakfast about 6 months ago, right after I finished the engine. No problems coming and going. I just finished reinstalling the rocker arm shaft to re-torque the head bolts. I never re-torqued them after my first drive. Noticed water had gotten into the pan so I drained and flushed the engine. Added new oil and filter. Found out where the water was coming from as 4 of the heads bolts were only 75 psi. With 105 psi on all head bolts, no more water and I drove it a few miles, backfired a few times. Went to a car show last weekend, only 5 miles away, engine quit on the way home. Had to have it towed.
Checked the plugs, running rich. Compression on all cylinders is 140-145. Have ordered a new condenser and coil, suggested by some of my Forum friends. Choke wire was also stuck in a rich position. The popping did not start when I first drove it.
Dick
DavidApp
+ 1 for the condenser.
My TR3A did exactly the same thing a while ago. Re set the points and got a couple of miles then the back firing again. Changed the points and got another couple of miles. Had a spare condenser so I changed that out. It has done 1500 miles since. I did get a condenser and rotor from the Distributer Dr. In the UK as a spare.
David
A engine stalling Triumph 8
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 12
L General Tech Engine id Triumph 9
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
