Engine 100/4
David:
e-Bay, watch and wait. I looked today, there is a bn1 transmission with OD and 100-4 cylinder head. Also, join both Healey clubs and put a parts wanted ad in their publications. Be patient, these parts are rare and most likely very expensive.
Austin Atlantic and some Austin cabs used the same engine with different manifolds and carburetors.
Good luck!
Try British auto salvage in Macedon NY, he may have what you need.
If you can't find one, make an amazing nasty boy!
If all else fails, this could still come in costing less than a 100 engine + a new aluminum cyl head (likely reqd) and the remainder of a rebuild...
https://www.jegs.com/i/Chevrolet-Performance/809/19257234/10002/-1
Of course, you'll want one of these too; again, not much off what a GOOD rebuild (parts + labor) would cost on an original.
https://www.jegs.com/webapp/wcs/sto...&submodel=&engine=&Nrpp=&No=&persistYmm=false
Just a suggestion ;)
-1
If you can't find one let me know. I will have a complete drive train for a BN1 when I'm done restoring mine. Not interested in selling it but I might be interested in buying your car.
Cheers,
Dan M.
A buyer would need to check that the front plate and timing gears are available with the Craigslist engine. Looks to have the correct cylinder head. Many Healeys have an A70 head fitted, but maybe not in the US where the A70 was not so common.
Hi Guys,
Anybody have any idea where to start on finding an engine for a 100/4 with trans and OD? Any help appreciated....
There is an engine listed in the current "Austin Healey" magazine (The club mag for AHCUSA) but it has been listed since January, so I don't know if it's still available (They aren't real good at pulling your ad when you're done) I didn't bring it with me today, but I can copy the contact info listed tomorrow.
Cheers,
Dan M.
R For Sale 100 engine block w/head Austin Healey Classifieds 3
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
Dandare 100/6 Engine Backplate Austin Healey 4
W Looking for engine rebuilding 100-6 Austin Healey 12
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
E For Sale Austin healy 100/4 complete engine Austin Healey Classifieds 4
L First 100 Engine Serial Number Plate Austin Healey 13
T Austin Healey 100 engine color Austin Healey 10
simon1966 A few shots from the 100 engine rebuild Austin Healey 18
A 1954 100/4 Engine specs Austin Healey 2
B 100-6 galley head engine - Do I feel lucky? Austin Healey 23
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
C Help!!! Austin Healey 100-6 engine problem Austin Healey 2
A 100 engine main bearing cap nut question Austin Healey 0
5 How not to start a freshly rebuilt 100/6 engine Austin Healey 30
simon1966 The 100 engine Austin Healey 9
H 100/4 engine block Austin Healey 0
T 100 Engine Lifting Device Austin Healey 25
OZ_BN1 100/4 Engine Austin Healey 12
W Replacement frame engine mounts for a 100-6 Austin Healey 4
J 100-4 engine hardware Austin Healey 17
Z 100 engine/gearbox adaptor plate Austin Healey 3
andrea AH 100/6 Longbrige 1957 engine comp,Wiring Harness Austin Healey 9
H 100 Engine Timing Chain Tensioner Austin Healey 3
G Early 100/6 engine, automatic transmission Austin Healey 2
H Need Healey 100 engine parts Austin Healey 4
HEALEYJAG 100-M engine on EBAY Austin Healey 2
T 1955 100-4 Engine Paint Austin Healey 8
AngliaGT TR6 TR6 Engine - $100 Triumph 5
mbrooks 100 oil leak from front of engine Austin Healey 3
mjobrien AH 100 - Chassis and Engine Numbers Austin Healey 8
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 0
R TR2/3/3A Engine revs up and down Triumph 6
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 17
L General Tech Engine id Triumph 9
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
