Electrical Issues Need Help
NYC5513
Hi All,
I am new to Healeys and this forum. I am starting to go through my 68 Sprite and this morning after starting the car the generator light stayed on after the car was running. That never happened so I shut off the ignition and went to restart the car. NOTHING??? No power to the ignition switch at all. No headlights or blower motor. I located a fuse panel in the engine compartment and only 2 glass fuses, one fuse has power in and out the other doesn't. Fuses are both good, but changed just in case although they have continuity. Is there a main fuse panel I am not seeing? My diagrams are terrible and I ordered a new one but thought I would post this to see if this is a common issue or a quick resolution? Almost like I am not seeing a power panel as I can't believe the whole car runs on only 2 fuses. Thanks for any assistance.
Steve
Have you checked the battery connections?
Yes, Battery is good and power to one side of the fuse block but not the other. That's why I am thinking there is another fuse panel or relay that I am not seeing??
Thank you for your response, I keep probing wires��
First of all, you will probably get more specific help on the Spridgets forum.
However, I'll take a stab. I think sprites are wired the same as other Healeys and, if so, then 2 fuses is correct - one is hot all the time and fuses the horns, the other is hot when the key is on and fuses everything else. It's always possible a previous owner may have added others.
If you have juice at the horn fuse but not the ignition switch, beyond the cleaning the battery terminals and chassis ground, the next place I would look is the battery cable connection on the solenoid, disconnect and clean - there will be at least one ring terminal & fairly large wire in addition to the battery cable and that is your main feed to the rest of the car, ignition switch, lights, etc. Whatever color that wire is, clean & tighten any connections you find.
Good luck and, again, repost to the Sprigets and hopefully you'll get some better guidance.
Dave
Thank you for the feedback. All was working fine, then gen light came on and car died. Tried to restart and nothing🤷🏼*♂️
Thank you to all that contributed. I found the issue, there was a loose lead at the back of the alternator that was causing the issue. Starts fine and charging good. Appreciate the help
D TR2/3/3A TR3A electrical issues Triumph 2
N TR6 Electrical Issues Triumph 5
I TR6 Electrical issues - please help. Triumph 5
pkmh BJ8 stalling out to due electrical issues Austin Healey 50
robdmau Electrical Issues... Spridgets 4
JodyFKerr Wedge Electrical issues [TR8] Triumph 67
Jim_Gruber Still fighting Fuel vs. Electrical issues Spridgets 12
T Still having issues with the electrical MG 5
R TR2/3/3A Intermitant electrical issues TR3A Triumph 3
vping Electrical issues worked out. MG 15
F Various Electrical Questions and Issues MG 11
W Ignition/ electrical issues? Spridgets 3
C TR2/3/3A TR3A Electrical problem Triumph 20
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N Electrical issue. FORUM Navigation Questions 2
C Ghost in the electrical system Austin Healey 51
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
