Hi All,
I am new to Healeys and this forum. I am starting to go through my 68 Sprite and this morning after starting the car the generator light stayed on after the car was running. That never happened so I shut off the ignition and went to restart the car. NOTHING??? No power to the ignition switch at all. No headlights or blower motor. I located a fuse panel in the engine compartment and only 2 glass fuses, one fuse has power in and out the other doesn't. Fuses are both good, but changed just in case although they have continuity. Is there a main fuse panel I am not seeing? My diagrams are terrible and I ordered a new one but thought I would post this to see if this is a common issue or a quick resolution? Almost like I am not seeing a power panel as I can't believe the whole car runs on only 2 fuses. Thanks for any assistance.
Steve
Steve
