Disc Brake conversion to BN2
Thomas591
Hi,
has anyone experience with the disc brake conversion kit on a 100 BN2?
-When using the original 100 brake master cylinder how does the pedal feel?
-Do I have to fit a brake servo?
-How is the front to rear balance with the stock rear drums? Do I have to fit a proportioning valve??
I am thinking of getting me the conversion set from Denis Welch / England -any experiences with this kit?
Bye
Thomas
rjhco
Thomas:
I have the DW rear disc conversion kit on my BJ8. I used Jaguar XJS calipers and discs on the rear. I only purchased the mounting brakets from DW. I sourced the brake calipers locally. The Jag XJS rear caliper pistons are 38mm while my BJ8 front caliper pistons are 52mm, providing more brakes in the front.
You should still install an adjustable proportioning valve. On lose surfaces, more rear brake is appropriate because the braking inertia that is transferred to the front brakes is less than on dry smooth surfaces. On the other hand, too much rear brake for a given condition will put the rear end in front with hard braking in a corner. You will need to experiment in a safe place to get the proportioning correct.
A servo should not be necessary. The amount of fluid transferred with pedal pressure when using disc brakes is less than with your BN2 drum brakes (another reason for a proportining valve).
Best regards,
Jim
mbrooks
Mine was already converted when I got it. There is no proportioning valve, but the back tends to lock on [very] hard braking so it's a good idea to fit one.
If you are selling the drum brake bits I might be interested in converting back - not because I don't like the discs, but because I am being excluded from some rallys because of the non-standard brake set-up.
Mike Brooks
56 BN2
Milano
Italy
tiga2
..I put on the Welch kit on my BN1, worked just fine, just make sure he sends the right bolts, he sent non british bolts for some reason, did we ever have a go around !!!
I have a non stock master cylinder, but nothing very new and all seems great, heck of a lot better than the drums.
Since I have a Chevy on mine, maybe I should have gone more exotic, but then again I wanted to keep it simple and easy.
Thomas591
Thomas591
Thanks folks for your answers...
What I have learned from them, is that the Welch kit for the front brakes should work nicely with the standard rear drums and that it is advisable to fit a proportioning valve.
What I am not so shure about is still the question if all works fine with the standard mastercylinder. I am so unsure, because years ago I converted my Sprite MK2 to front diskbrakes and hat to change the mastercylinder because with the standard drumbrake m.-cylinder the pedalforces necesaary were unbelievable to stop the car.
Please advise again.
Thomas
I Bug eye front disc brake conversion. Spridgets 5
A AH 3000 rear disc brake conversion Austin Healey 28
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
B Disc brake conversion Spridgets 12
Jim_Gruber Steering Arms for BE Disc Brake Conversion Spridgets 1
T Disc brake conversion questions Spridgets 5
bugedd Disc brake conversion Spridgets 7
steveg First drive - Toyota 4-piston Disc Brake conversion Austin Healey 5
S Rear Disc Brake Conversion Austin Healey 9
J Disc Brake Conversion on Sprite Austin Healey 1
drooartz My writeup on disc brake conversion Spridgets 14
K disc brake conversion Spridgets 11
K Disc brake conversion Spridgets 2
E Bugeye Disc Brake Conversion Spridgets 2
livinginthepast Disc brake conversion - soft pedal Spridgets 8
M BN4 prob with disc brake conversion[front] Austin Healey 2
Fortius Dennis Welch Rear Disc Brake Conversion Kit Austin Healey 2
BIBBER Disc Brake Conversion Restoration & Tools 7
E 60 Bugeye Disc Brake Conversion Spridgets 28
B Disc Brake conversion Austin Healey 1
bcliff '61 Morris Minor Disc Brake Conversion Other British Cars 3
T xk140 disc brake conversion Jaguar 0
F Disc Brake Shimming Austin Healey 8
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K Disc Brake Conversation to MK1 Midget Spridgets 2
A Disc Brake pictures Austin Healey 1
BJ8Healeys Disc brake piston seals Spridgets 2
K TR2/3/3A Brake disc? Triumph 19
NutmegCT Disc brake fun Other Cars 33
B Another disc brake question Spridgets 10
K TR2/3/3A Front disc brake squeal.... Triumph 4
R BJ7 Front Brake disc hitting Austin Healey 12
jaegzie Disc brake upgrade was fine now major alignment issue. Spridgets 6
DanLewis Disc brake setup on eBay for $79+shipping [NFI] Spridgets 2
Lynn Kirkpatrick MGB Disc brake pads MG 4
tahoe healey disc brake anti squel pads Austin Healey 5
AHS TR2/3/3A Disc brake line routing Triumph 0
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
C 100 Drum Brake Keep or upgrade to disc? Austin Healey 9
S rear disc brake conversions brackets Triumph 9
M BJ7 Rear Disc Brake Setup Austin Healey 7
I Disc brake question Austin Healey 1
D Disc brake rotors Austin Healey 10
M MGA MGA Disc Brake Axles? MG 2
J How to install disc brake seals. Austin Healey 1
19_again GT6 disc brake piston removal GT6+ Triumph 8
B TR6 TR6 Disc Brake rattle Triumph 2
