Cylinder wall has some build up. Need to clean.
jaegzie
Putting the 1275 in the bugeye went through the fun of wiring, had it all wired. Pulled the starter switch and the starter moved for a split second nothing else except some smoke coming from the switch.
The engine ran when I sold it to someone in my 64 sprite. He pulled it to do a swap. It sat on his garage floor since. Never outside. I bought it back for my bugeye. Put it in and it was locked up. I oiled the cylinders multiple nights with marvel but no change. I got a socket to turn the crank bolt and the engine would spin one cycle when the 2&3 cylinders got to the top it would freeze.
Popped the head of to find rust at the top of 3 cylinder. It doesn't look major and I didn't force the piston into it. This was a running engine 5 months ago. Is this something I can try cleaning? This engine is for getting the car going and then will be pulled for one that will be rebuilt and cleaned etc....
I searched here and found a couple different ideas but just want to get some good tips and things not to do! Thanks.
also looking at the picture the rust that appears to be on the cylinder wall is from the top and the oil. It wipes away with my finger and is spotless. My concern is the top ring.
JPSmit
I don't see why not. Take out at least that piston, do a light hone and clean clean clean the rings. That said, if I had it apart, for not a lot of money you can do a ring job and possibly bearings and have an engine that will last a lot longer. And it really won't take you any more time.
i would also want to know why the rust is there. Head gasket?
jaegzie
jaegzie
I'm guessing the head gasket was going from looking at it. There wasn't anything obvious but from the looks of the engine this hasn't been apart in a Long long time. Looks like I get to pull this engine out now then pull my other one and swap them! I may as well pull it apart and rebuild this one since I was going to rebuild one anyway.
Thanks for for the reply.
Spridget64SC
Check the brass plug that corresponds to the marks on the head gasket in the photo. It looks to be recessed from the way the headgasket is discolored/marked between cylinders 2 & 3.
Drill and pull the plug. Tap for 3/8" npt solid brass pipe plug. Insert tightly and then surface head for new gasket surface.
Common problem on 1275 heads. Address any of the plugs that have recessed.
HTH,
Mike
K TR2/3/3A Cylinder head stud height question? Triumph 4
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
W Cylinder compression Hillman super minx Other British Cars 15
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
Donald1107 TR2/3/3A low cylinder compression Triumph 12
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
S TR2/3/3A rear wheel cylinder Triumph 1
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
6 Master Cylinder Actuator rods Spridgets 2
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
6 Master Cylinder Install Spridgets 5
Patrick67BJ8 Cylinder Compression Checks Austin Healey 30
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR6 Rear brake wheel cylinder fitment Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
