Cylinder compression Hillman super minx
Westhoff
Hi out the, I have a 1966 Hillman super minx and the cylinder compression is low on 2 cylinder would Ametech engine Restore help improve the cylinder compression or should I leave well alone.
Thanks for looking Walter from Walton Liverpool Merseyside England
Administrator
Boss
I moved your post to "Other British Cars". You had posted it in our Member Articles forums which, as the name implies, is for articles (minimum 500 word articles, like you might read in a magazine). Cheers, Basil
NutmegCT
Hi Walter - welcome to BCF.
When I first got my 1957 Morris Minor, two cylinders had much lower compression than the other two. After some reading here and elsewhere, I decided to use a 50/50 mixture of acetone and power steering fluid, and drip it down into each cylinder.
Let stand overnight, then did the compression tests again. This time all four cylinders were within 4 psi of each other. I figure that the 50/50 mixture seeped down and loosed the piston rings, which evidently fixed the compression problem.
There are other products, such as Seafoam, which will do the same thing. But there are several other problems which lower cylinder compression, beside stuck piston rings!
Hope this helps.
Tom M.
W
Westhoff
Hi Tom M, thanks for the information. I've been toying with the idea of using different engine restorer products for awhile. I know a mechanic that only does classic car restoration he says that all the products work to some degree but it's not the answer, in fact he says just leave it alone, it's an old car and is bound to have problems like low compression. He says it goes fast enough and doesn't smoke so just enjoy it for what it is !! He says just keep the oil and water topped up and forget about it until it becomes a real problem. Enjoy is the word.
I think I'll take his advice but thought I'd ask the BCF.
Thanks again Walter from Liverpool Merseyside England
NutmegCT
Enjoy is the word.
That's a great way to look at it, and is the reason most of us are into classic cars.
As I often see here on BCF - Drive it like you stole it!
Tom M.
PS - I like that "shift pattern" badge on your front bumper. Never seen one of those before.
W
Westhoff
Hi Tom M, some pictures for you. The badges came from Gumtree plus badge bar all the way from Scotland.
Built my own speakers cabinet and fitted 30 years old radio. So it runs OK πŸ‘Œ, so happy days.
W
Westhoff
Thanks Basil for moving my post. Walter from Walton Liverpool Merseyside England
NutmegCT
Hi Walter - that "shift pattern" badge shows the Dowty Motor Club. Here's some history for you:
And some background on the Dowty Group, which has quite an interesting history, and was very well respected in the area.
Tom M.
PS - how are the Walton Wanderers doing?
W
Westhoff
Tom M.
Walton Wanderers are based in Surrey I'm in Liverpool. Thanks have a great Christmas Walter
JPSmit
My wife's parents came from Liverpool and their ashes are spread in the Mersey. My wife and her sister literally to 'the ferry cross the Mersey' and it stopped part way, the captain made an announcement, accompanied them to the spot. Very meaningful for literally the fare for the ferry. :cheers:
W
Westhoff
Sounds like they had a good send off
Have a great Christmas Walter
waltesefalcon
Hello and welcome Walter from Walton. Your Hillman certainly is a lovely little minx, isn't it?
I would tend to agree with your mechanic friend. If it isn't smoking or running poorly then leave it as is.
W
Westhoff
Thanks for your interest and compliment on my Hillman. Yes leave well alone, if it's not broken down try to fix it, an old adage but very true!! Happy Christmas and New Year Walter
W
Westhoff
If it's not broken don't try to mend it, is what I meant to say. Walter from Walton
JPSmit
One thing not mentioned is how low? If it is a few pounds low then sure, additive and drive it like you stole it. (I use Lucas Oil Stabilizer is it is good for 5-lbs of poil pressure) If it is a lot lower a head gasket is the way to go - and while I am not familiar with Hillman's it should be an easy fix. Pop the head, confirm straightness, replace the gasket, torque new bolts and Bob's your uncle.
Donald1107 TR2/3/3A low cylinder compression Triumph 12
Patrick67BJ8 Cylinder Compression Checks Austin Healey 30
M TR6 High Compression in One Cylinder Triumph 28
Gliderman8 TR6 Compression help in one cylinder Triumph 7
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
S TR2/3/3A rear wheel cylinder Triumph 1
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
6 Master Cylinder Actuator rods Spridgets 2
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
6 Master Cylinder Install Spridgets 5
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR6 Rear brake wheel cylinder fitment Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
