TR6 Compression help in one cylinder
Gliderman8
Compression help one cylinder is low
As some of you may remember, in May I bought a '76 TR6 to restore. Over the last few weeks I've rebuilt the carbs, and drained and cleaned the gas tank.
I finally started it up a few days ago and have been trying to tune it as well as get the carbs set correctly. This morning, I had the car running while making some adjustments and heard a noise coming from the engine that you know when you hear it, its not good. It didn't make the banging sound continuously, but it did it every once in a while. I pulled the plugs and did a compression test and I don't like what I found so I'm looking for advice as to which way to proceed.
Here's the compression results (dry):
1=110 2=100 3=45 4=100 5=105 6=110
Obviously #3 has a problem. I added some oil to #3 cylinder and redid the test and this time it only came up to 60 lbs.
What is the best way to determine if its the valves or rings? If it is broken rings in #3 then whats to best way to proceed?
Thanks for any help.
Deleted member 8987
First, do a wet test. One squirt of oil in each hole, crank a couple of times, and re-do the test. If it's worn rings, you'll see a substantial jump in readings.
Poor man's leakdown is a fitting on an air hose that matches your plugs.
Remove rocker assembly. Air up each hole, listen for air out carbs, exhaust, adjacent holes.
I would also be looking closely at valve springs. Push down with the palm of your hand on each valve. Does one (especially the low hole) go down MUCH easier than the rest?
Could also be your source of noise.
Once you have done that, and it all checks out, it's broken rings or piston or both.
Dave
Geo Hahn
Remove rocker assembly. Air up each hole, listen for air out carbs, exhaust, adjacent holes...
Just to expand on that:
Many compression gauges have a quick-connect on the gauge -- remove the gauge and what you're left with is a hose with a quick-connect on one end and spark plug threads on the other.
To do this test you want the cylinder to be at TDC on the compression stroke. I also have it in gear and handbrake set though in theory the piston won't move it you are exactly at TDC.
Gliderman8
Gliderman8
Thank you gentlemen... I will need to get a hose with the proper fittings.
George: I do have a compression gauge, but I'll have to look and see if it has the quick connect on one end.
Gliderman8
Gliderman8
To make matters worse, I just went to reinstall the plugs and I notice #3 spark plug has had the tip pushed in; ie, the gap is closed. Could a bad valve have done that?
Deleted member 8987
All stop. Plug smashed is something inside the bore. Added to that low compression, just pull the head, pan, and piston/rod.
Plan on a full rebuild.
Sorry.
Dave
TR3driver
Great Pumpkin - R.I.P
That was my comment: you know there is something bad in #3, might as well pull the head and find out what. Since you are "restoring" the car, I can't see any reason not to restore the engine as well.
svtmikey
Yes, all stop.....no way to have the plug smashed if all is ok...very bad
Just as a comment, better way to check things is a leak test.....we don't do compression tests very much anymore.
A Leak tester is relatively cheap, you position the cylinder you are checking so it is TDC with all the valves closed and then pressurize it with compressed air then see how much air is leaking out of the cylinder.
A certain amount of leak is allowable, most gauges show what is acceptable.
The advantage is it tells you where the problem is.
You simply then "listen for where the air leak sound is.
If you hear it out of the exhaust pipe.....exhaust valves
Radiator.....most likely means head gasket
Intake.....intake valves
Oil filler/ dipstick....looks like rings.
Pretty easy and a lot less guessing
Good luck on the problem though
Not saying you never use a compression test, but there are more precise ways of trouble shooting.
eschneider need help with compression test readings...... Other Cars 7
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
petnatcar Compression Test Record Form Austin Healey 0
W Cylinder compression Hillman super minx Other British Cars 15
Donald1107 TR2/3/3A low cylinder compression Triumph 12
kodpkd Compression Test Results Austin Healey 1
Patrick67BJ8 Cylinder Compression Checks Austin Healey 30
B TR4/4A Finding compression stroke Triumph 7
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY Compression test results Austin Healey 17
S TR2/3/3A Compression Triumph 8
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
NutmegCT Variable compression? Other Cars 22
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
R TR2/3/3A Good Compression Triumph 1
3798j Fastronix Battery Compression Ends Restoration & Tools 4
F TR2/3/3A Compression Test Triumph 13
K TR2/3/3A Compression testing again... Triumph 4
HighAltitudeTR3 TR2/3/3A Compression Question Triumph 10
warwick-steve High compression head identification Austin Healey 16
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Jim_Gruber Bugsy IV and Engine Compression :[ Spridgets 11
Martinld123 Compression check 1956 BN2 Austin Healey 7
2 TR2/3/3A compression numbers Triumph 1
P TR6 Latest compression test Triumph 11
MY66AH Compression woes Spridgets 11
S Unexpected Compression Readings Austin Healey 14
tinman58 TR2/3/3A Surprise on compression. Triumph 9
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
T TR6 TR6 compression test Triumph 12
B TR6 Fuel tank to line compression fitting Triumph 1
tinman58 TR5/TR250 Compression # Triumph 9
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
M Compression test results Austin Healey 11
R TR2/3/3A Steering, stator tube compression sleeve? Triumph 4
Kleykamp TR2/3/3A compression numbers & smoking engine Triumph 20
S Bugeye 948cc Compression Spridgets 7
L 1275 Compression, Camshaft, et al Spridgets 16
me61ic Compression results - Worth Rebuiding? Austin Healey 13
D Compression #'s Triumph 13
Tinkerman TR2/3/3A 60 TR3A Compression test Triumph 15
D Austin Healey 100-6 Compression Austin Healey 1
P TR6 1971 TR6 compression Triumph 2
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
T Milling a head on a Stock 1275 for compression? Spridgets 13
RichBall For us 1500 guys, high compression head up on Ebay Spridgets 10
M TR4/4A TR4 Optimal Compression - 91 Octane Pump Gas Triumph 13
pkmh Compression Test Results for BJ8 Austin Healey 14
TulsaFred 1275 compression ratios and horsepower Spridgets 29
