TR4/4A Finding compression stroke
bammons
I have searched and don't really find the answer for this although I am sure it is here somewhere. I need to mount my distributor from scratch as someone (me) did not adequately prepare when it was removed. The instructions are saying I need to be at TDC on the compression stroke. I know TDC from the flywheel mark but I understand it is not the same. I placed a piece of paper over the spark plug hole and can see when it blows out but there must be a more accurate way of determining this. My valve cover is off, and as I said I have access to the flywheel mark. My timing cover is off as well but I have new unmarked gears. Thanks Bruce
sp53
The piston comes up and pushes the paper away at that point you stop spinning the engine and look for the 2 marks; one on the timing chain cover and the other on the pulley. Now by hand by turning the fan/pulley you Line those 2 marks up and you are done. The mark on the pulley will probably go past the mark on the cover by about a one inch or maybe an inch and half, so you have to bring them back to TDC compression stroke
Sarastro
If your timing cover is off, your crank pulley is also off, so you don't have timing marks that are normally used. I think your only option is to put a screwdriver into the #1 plug hole and LIGHTLY feel when the piston is at the top of its stroke. If the #1 valves are both closed, that's TDC on the compression stroke. For installing the distributor, that should be good enough.
poolboy
I'm not familiar with the TR4 engine, but is it even possible to install the distributor any way but the way it was removed ?
I ask because the TR6 distributor shaft has a slightly off set driven dog which will seat back in place in the engine oriented only one way.
FWIW, if you do need to distinguish between TDC at compression and TDC at exhaust, I wouldn't rely on the paper as an indicator. The piston will be pushing air out of the cylinder on both strokes.. and there be air coming out an open spark plug hole as well as thru an open exhaust valve on the exhaust stroke...more thru the path of least resistance.
Closed valves would be the best indicator IMO.
bobhustead
Watch the #1 valves. Exhaust will open and close, then intake will open and close. At intake closure, you are at about BDC on the beginning of compression stroke. Turn the crank another 90 degrees or so and put a probe (small screwdriver, length of coat hanger, dowel, or something rigid and plastic) and feel for the piston. Turn it a little more and feel again. As it nears the top, you can leave the probe in the hole and watch/feel it crest and begin downward. The highest point is TDC compression. Another clue is the short radian of reduced effort to turn the crank. This is because all crank throws are at top or bottom and you are moving the rod big ends side to side rather than up and down.
Bob
steveg
These both work - a HF compression tester and a homemade setup with a spark plug boss on the right (with a rubber seal) and the finger off a glove as a balloon:
B
bammons
Ok thanks for the advice to all. Hopefully I can get it with your suggestions. On a related note I have in addition to the new unmarked timing/crank gears decided to convert to the narrow belt option which of course includes a new crankshaft pulley (unmarked). Can I use the arrow on the flywheel for TDC and then drill my new pulley (as the original) at the marker on the timing cover for TDC? Bruce
sp53
Yes as long it is TDC compression. I do not see why not. you can look inside at #1 with a flashlight to see when it is up.
D Finding a Posting FORUM Navigation Questions 4
G TR2/3/3A Finding a long lost TR3 Triumph 4
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
O Finding Gerard Spridgets 9
A TR2/3/3A Need Helping finding windshield bracket! Triumph 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
T Finding an accurate tyre pressure gauge? Spridgets 5
B TR4/4A Need Help Finding Triumph 3
T Finding help to actuallyl get projects completed Spridgets 4
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
M TR2/3/3A Finding top dead center Triumph 6
E Need help finding the builder to my 65 Spridgets 18
C Need Help Finding Torque Specs for Engine Austin Healey 1
S TR6 Finding a 69 tr6 Triumph 2
jhorton3 Finding Midgie A New Home Spridgets 0
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
justin_mercier Post-War Other Need help finding a triumph 2000/2500/2.5pi autobox transmission Triumph 10
R Finding old posts Austin Healey 5
S I need help finding a correct bolt. Austin Healey 8
A Finding the fun stuff! Triumph 4
7 finding a coolant leak Other Cars 8
F Need help finding a part- door window track piece Austin Healey 5
richberman Help in finding part: Longbridge hot air outlet Austin Healey 3
T finding a coolant leak Austin Healey 3
J Finding a correct 1964 BJ8 steering wheel Austin Healey 1
T Finding engine ID Austin Healey 7
N Help finding a part Triumph 7
T help finding stromberg parts Triumph 5
T longer wheel studs need help finding Triumph 11
A TR6 Finding TR6 Project? Triumph 22
R Help finding part Jaguar 3
M Finding Tires for Midget??! Spridgets 8
Basil Help finding part Jaguar 11
wkilleffer MGB Finding 74 MGB starter stuff near Chattanooga, TN MG 4
M finding vendor Spridgets 1
M finding vendor Austin Healey 3
Cyberpyr8 Need help finding a solution Triumph 23
T Brainstorm me a disagnostic finding Triumph 14
GeeBee1 TR6 Finding a late model TR6 Triumph 9
T Help finding grounding clips Triumph 6
G Finding TDC or Waiting For Godot Triumph 17
S Need Help Finding a Part Austin Healey 1
B Finding 50A Fuse for Horn Locally? Austin Healey 15
G Try finding THIS short..... Triumph 9
Bayless Finding TDC on a flathead motor Other British Cars 16
M Finding an old healey Austin Healey 5
bash Electrical fault finding Triumph 8
J Finding Exhaust Leak MG 4
floyd TR6 finding a tr6 repair manual Triumph 14
