Finding engine ID
twas_brillig
I went out to find my engine ID this evening (BJ7); the firewall plate provides the VIN but advises all and sundry to look at the engine for its identifier. I looked and didn't find; suggestions as to what to look for (I presume one of those slim metal strips?) and where?
Thanks,
Doug
In this picture, the engine i.d. tag would be just behind the waterpump inlet, and below the #1 exhaust port.
There's a flat ledge, so if there's no tag, it was likely removed/destroyed (they melted in the caustic solution used to boil out the blocks) during a rebuild.
T
twas_brillig
Thanks guys - sure a lot easier when you know where to look. And it appears that I'm a genuine 29F /BU/H577.
However - the whole purpose of this exercise was to find out what the gear ratios were so I can calculate speeds vs. tach readings, and Haynes advises that the ratios changed at engine no. 10897 (with overdrive) - which doesn't seem to match what I've got.
Any suggestions as to what the Haynes manual is talking about? My Bentley/shop manual is loaned out, so can't check there.
Thanks,
Doug
Duane_Rhynard
Doug,
Attached are the speed / gear ratio charts for both for 22% and 28% overdrives.
Hope this helps!
Duane
58 BN6
  • 22242.pdf
While a little harder to find, I believe the actual tooth count (pinion/ring gears) is stamped on the removeable portion of the axle assembly__the differential.
I'm still 300 miles from home, but we're headed in that direction, so maybe I can get a picture later this evening.
In the meantime, I can tell you where to look, and you might get lucky! Look where the bearing retaining cap studs protrude through the case (facing forward).
Duane_Rhynard
Randy is correct (As always!)
Attached are the pictures he was referring to: the ratio stamped on the ring gear and the ratio stamped on the case, which should match unless the ring and pinion have been changed.
  • 22247.pdf
BJ8Healeys
There were two differential ratios used on 3000s: 3.909 for a car equipped with overdrive, and 3.545 for non-overdrive. The 3.909 had 11 pinion teeth and 43 crown wheel teeth (43/11 = 3.909, although it is stamped on the diff 11/43), which is what the numbers are that are stamped on the differential in the photo posted by Duane. The 3.545 had 11 pinion teeth and 39 crown wheel teeth (39/11 = 3.545).
When a BJ7 engine was to be mated with an overdrive gearbox, its serial number included an "R", which signified Laycock de Normanville overdrive: e.g., 29F/RU/H577. If the engine was to be mated to a non-overdrive gearbox, the "R" was omitted: 29F/U/H577.
I have no clue how Haynes came up with the engine number 10897 "with overdrive". There is no such change point specified in the BMC BJ7 and BJ8 parts manual -- either for engine, gearbox, or rear axle. Also, the "overdrive" and "non-overdrive" engine serial numbers did not fall in such a neat sequence.
As mentioned, engine serial number plates will dissolve in hot tank chemcals, but they can be removd to prevent that. Once the plate is gone, there is absolutely no way to positively identify that engine anymore.
C Need Help Finding Torque Specs for Engine Austin Healey 1
D Finding a Posting FORUM Navigation Questions 4
G TR2/3/3A Finding a long lost TR3 Triumph 4
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
B TR4/4A Finding compression stroke Triumph 7
O Finding Gerard Spridgets 9
A TR2/3/3A Need Helping finding windshield bracket! Triumph 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
T Finding an accurate tyre pressure gauge? Spridgets 5
B TR4/4A Need Help Finding Triumph 3
T Finding help to actuallyl get projects completed Spridgets 4
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
M TR2/3/3A Finding top dead center Triumph 6
E Need help finding the builder to my 65 Spridgets 18
S TR6 Finding a 69 tr6 Triumph 2
jhorton3 Finding Midgie A New Home Spridgets 0
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
justin_mercier Post-War Other Need help finding a triumph 2000/2500/2.5pi autobox transmission Triumph 10
R Finding old posts Austin Healey 5
S I need help finding a correct bolt. Austin Healey 8
A Finding the fun stuff! Triumph 4
7 finding a coolant leak Other Cars 8
F Need help finding a part- door window track piece Austin Healey 5
richberman Help in finding part: Longbridge hot air outlet Austin Healey 3
T finding a coolant leak Austin Healey 3
J Finding a correct 1964 BJ8 steering wheel Austin Healey 1
N Help finding a part Triumph 7
T help finding stromberg parts Triumph 5
T longer wheel studs need help finding Triumph 11
A TR6 Finding TR6 Project? Triumph 22
R Help finding part Jaguar 3
M Finding Tires for Midget??! Spridgets 8
Basil Help finding part Jaguar 11
wkilleffer MGB Finding 74 MGB starter stuff near Chattanooga, TN MG 4
M finding vendor Spridgets 1
M finding vendor Austin Healey 3
Cyberpyr8 Need help finding a solution Triumph 23
T Brainstorm me a disagnostic finding Triumph 14
GeeBee1 TR6 Finding a late model TR6 Triumph 9
T Help finding grounding clips Triumph 6
G Finding TDC or Waiting For Godot Triumph 17
S Need Help Finding a Part Austin Healey 1
B Finding 50A Fuse for Horn Locally? Austin Healey 15
G Try finding THIS short..... Triumph 9
Bayless Finding TDC on a flathead motor Other British Cars 16
M Finding an old healey Austin Healey 5
bash Electrical fault finding Triumph 8
J Finding Exhaust Leak MG 4
floyd TR6 finding a tr6 repair manual Triumph 14
