finding vendor
mightymidget
As you can see this is one of first request, very new to forum.
During another midget project years ago seems like a ran into a shop in upstate South Carolina that was good on major suspension work.I am in process of aquiring a Bugeye that I want to research will I am waiting. Didn't see any shops on forums vendor list that did racing suspensions,modifications etc...
Any one care to lead me to a good thread, articles, or shop in South Carolina area that I can research. Vehicle has V-8 and very concerned about weight difference, brakes etc..
I also put this request in spriget section
GregW
Hi Mighty,
Are you looking for someone to do the work for you in SC, or are you looking for a parts supplier and you'll do it yourself? If you are interested in swaybars try Addco. Oddly they're in North Carolina.
M
mightymidget
Actually I just want to do some research as to what would be a good set up for street. I know car will need major review. and I want to update suspension and brakes but it takes alot of time for me to make the descisions. I will do as much of the work as I can but I have limited welding capabilities. I like be able to talk in person at the shops
M finding vendor Spridgets 1
D Finding a Posting FORUM Navigation Questions 4
G TR2/3/3A Finding a long lost TR3 Triumph 4
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
B TR4/4A Finding compression stroke Triumph 7
O Finding Gerard Spridgets 9
A TR2/3/3A Need Helping finding windshield bracket! Triumph 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
T Finding an accurate tyre pressure gauge? Spridgets 5
B TR4/4A Need Help Finding Triumph 3
T Finding help to actuallyl get projects completed Spridgets 4
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
M TR2/3/3A Finding top dead center Triumph 6
E Need help finding the builder to my 65 Spridgets 18
C Need Help Finding Torque Specs for Engine Austin Healey 1
S TR6 Finding a 69 tr6 Triumph 2
jhorton3 Finding Midgie A New Home Spridgets 0
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
justin_mercier Post-War Other Need help finding a triumph 2000/2500/2.5pi autobox transmission Triumph 10
R Finding old posts Austin Healey 5
S I need help finding a correct bolt. Austin Healey 8
A Finding the fun stuff! Triumph 4
7 finding a coolant leak Other Cars 8
F Need help finding a part- door window track piece Austin Healey 5
richberman Help in finding part: Longbridge hot air outlet Austin Healey 3
T finding a coolant leak Austin Healey 3
J Finding a correct 1964 BJ8 steering wheel Austin Healey 1
T Finding engine ID Austin Healey 7
N Help finding a part Triumph 7
T help finding stromberg parts Triumph 5
T longer wheel studs need help finding Triumph 11
A TR6 Finding TR6 Project? Triumph 22
R Help finding part Jaguar 3
M Finding Tires for Midget??! Spridgets 8
Basil Help finding part Jaguar 11
wkilleffer MGB Finding 74 MGB starter stuff near Chattanooga, TN MG 4
Cyberpyr8 Need help finding a solution Triumph 23
T Brainstorm me a disagnostic finding Triumph 14
GeeBee1 TR6 Finding a late model TR6 Triumph 9
T Help finding grounding clips Triumph 6
G Finding TDC or Waiting For Godot Triumph 17
S Need Help Finding a Part Austin Healey 1
B Finding 50A Fuse for Horn Locally? Austin Healey 15
G Try finding THIS short..... Triumph 9
Bayless Finding TDC on a flathead motor Other British Cars 16
M Finding an old healey Austin Healey 5
bash Electrical fault finding Triumph 8
J Finding Exhaust Leak MG 4
floyd TR6 finding a tr6 repair manual Triumph 14
