Finding TDC or Waiting For Godot
G
The enigma of TDC is such that achieving it is oft a trick.
My lightbulb went off this morning while gazing at my headless block. Rather than bump the starter, or try to re-affix a bolt to the crank from which I can turn from, why not just put her in fourth gear (she is on blocks) and very easily turn my rear wheel back and forth and watch my dial gauge do its thing.
Mickey Richaud
Way to go there, Estragon! :wink:
Brosky
Once again, necessity is the mother of an inventive mind. Sort of para-phrased, but you get the general idea.
DNK
Been doing that for years on the old cars. One thing,just like it is easy to go past the spot when you turn by hand it tends to move easily past that point when you push it
G
Should be able to move it back and forth, right. The crank will turn backwards with no effort? Talking smidgens of movement here, especially when using the dial gauge.
Dave Russell
Yoda - R.I.P
As long as the head is off, check into the "positive stop" with degree wheel method of finding TDC. Much more sure & accurate than dial indicator.
Also, you really should use the degree wheel & dial indicator to check cam timing when you replace the cam.
DNK
Used to rock back and forth. of course a little easier (maybe) on a Cortina with an outrageous Formula Ford motor.
70herald
I picked up a big socket which fit the nut on the end of the crankshaft. Very easy to move the engine back and forth. I used it both while assembling the engine (to find TDC) and later on to set the valves. Much easier than pushing the car back and forth.
G
Yisreal, the car is on jack stands. I can just reach back and turn the tire like a steering wheel. Or let the wife do it.
T
Tinster
Morning Bill !!
I've been up since 4:30 AM AST doing some yellowfin tuna
research. What miserable local time did you get of bed
this morning? 3:30AM??
Raining cats and dogs here.
d
70herald
You must have really long arms and an angel for a wife. :laugh:
Using the socket, you really have much more accurate / easy control over positioning the engine. After all, even in 4th gear, you still have the ~4:1 ratio from the differential in between the tire and the engine you are turning over.
Twosheds
I'm like Dave Russell. Seems to me that a dial indicator will find Top Center but not Top Dead Center. Due to the few degrees of crank rotation that do not move the piston because of slop.
We used to have a tool (I forget its name) that screwed into a spark plug hole and stopped the piston on its way up. You then zeroed the degree wheel. Then you backed up the prop... er, crank 'til the piston hit it again and noted the degree mark.
Top Dead Center was half of this degree mark.
The fact that you were still moving the piston up when it hit the stop meant that all the slop was taken up.
Platinum
Hard to do if the head's already off, John. :smirk:
The same thing CAN be done with the dial indicator and degree wheel, it just takes more patience to achieve. A bar attached to the top of the block (head bolt hole) with a "stop" hanging into the bore is a good surrogate... *hint-hint* :smile:
JFS
Bronze
Bill, If I remember correctly, Godot never shows; however, TDC can be had :smile:
Twosheds
Silly of me.
swift6
Such as this...
The two outer bolts are to attch to the deck of the block, the center post is the stop.
TR3driver
Great Pumpkin - R.I.P
:iagree: But you still need a degree wheel (or careful measurements on the rim of the pulley/damper) to find TDC. The stop only gives you two points equally spaced on each side of TDC.
Of course, as noted, so does the dial indicator, except with it, they are NOT evenly spaced.
vettedog72
TDC accuracy on the TR6 may be limited by the tolerances of the crankshaft or some other factors like rod length, piston pin to piston top. As dumb as this may sound there is some significant slop with these parts. I recall the decking procedure brings these tolerances to light. If your motor is apart measure the deck to piston top on each cylinder and you will see the dofferences; you may be able to eyeball the differences in heights
Bayless Finding TDC on a flathead motor Other British Cars 16
D Finding a Posting FORUM Navigation Questions 4
G TR2/3/3A Finding a long lost TR3 Triumph 4
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
B TR4/4A Finding compression stroke Triumph 7
O Finding Gerard Spridgets 9
A TR2/3/3A Need Helping finding windshield bracket! Triumph 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
T Finding an accurate tyre pressure gauge? Spridgets 5
B TR4/4A Need Help Finding Triumph 3
T Finding help to actuallyl get projects completed Spridgets 4
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
M TR2/3/3A Finding top dead center Triumph 6
E Need help finding the builder to my 65 Spridgets 18
C Need Help Finding Torque Specs for Engine Austin Healey 1
S TR6 Finding a 69 tr6 Triumph 2
jhorton3 Finding Midgie A New Home Spridgets 0
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
justin_mercier Post-War Other Need help finding a triumph 2000/2500/2.5pi autobox transmission Triumph 10
R Finding old posts Austin Healey 5
S I need help finding a correct bolt. Austin Healey 8
A Finding the fun stuff! Triumph 4
7 finding a coolant leak Other Cars 8
F Need help finding a part- door window track piece Austin Healey 5
richberman Help in finding part: Longbridge hot air outlet Austin Healey 3
T finding a coolant leak Austin Healey 3
J Finding a correct 1964 BJ8 steering wheel Austin Healey 1
T Finding engine ID Austin Healey 7
N Help finding a part Triumph 7
T help finding stromberg parts Triumph 5
T longer wheel studs need help finding Triumph 11
A TR6 Finding TR6 Project? Triumph 22
R Help finding part Jaguar 3
M Finding Tires for Midget??! Spridgets 8
Basil Help finding part Jaguar 11
wkilleffer MGB Finding 74 MGB starter stuff near Chattanooga, TN MG 4
M finding vendor Spridgets 1
M finding vendor Austin Healey 3
Cyberpyr8 Need help finding a solution Triumph 23
T Brainstorm me a disagnostic finding Triumph 14
GeeBee1 TR6 Finding a late model TR6 Triumph 9
T Help finding grounding clips Triumph 6
S Need Help Finding a Part Austin Healey 1
B Finding 50A Fuse for Horn Locally? Austin Healey 15
G Try finding THIS short..... Triumph 9
M Finding an old healey Austin Healey 5
bash Electrical fault finding Triumph 8
J Finding Exhaust Leak MG 4
floyd TR6 finding a tr6 repair manual Triumph 14
