Hi all,
I'm still working on getting my clutch working again. Unfortunately two hurricanes (Frances and Jeanne) have caused this to become a rather lenghty exercise. However the car is now back out from under all the other stuff that was put in the garage.
I rebuilt the clutch master cylinder with the rebuild kit and re-installed it. So far so good.
Then I went to bleed the system and after I got a little fluid out of the bleed nipple on the slave cylinder it just stopped. I can't seem to get any fluid to flow now. The system doesn't seem to be leaking anywhere so I am thinking that either it has an airlock in there or it's got some crud that is blocking it.
Any thoughts?
Any thoughts?
