clutch 1969 sprite
knefelkamp
hello i have a 1969 austin healey sprite 1275cc i have a cluch problem i have very soft cluch peadle can not shift into 1st gear with engine running or any other gear can put in gear and start car and car will stay put with cluch in
i have installed a new cluch master cyl new slave cyl new steel line and a new rubber hoes and all copper washers and tethlon tape on the fittings
also have put in a new clutch new cluchplate new pilot bushing new bearing still works the same and a new push rod on the slave cyl and the fork is in the right way same as the cluch thanks for your help
GeeBee1
Welcome:
The first and easiest question to ask is are you sure it is fully bleed, they can be a real bogger to do. Especially, if the Master and Slave are new.
Pat
IanIrving
Is the flexible pipe ok? If the cloth covering is broken it can swell on pushing the pedal and then the clutch doesn't disengage and the pedal feels soft.
Ian
GeeBee1
Ian
hmmm good one Ian.
Pat
My money says that there's still air in the system.
Bleed the master cylinder first: to do this properly, take an old section of your steel tube, and cut/bend it so that from the output port, it goes into the reservoir below the fluid level.
Slowly stroke it a few times to expell all the remaining air.
Reconnect the new steel pipe down to the slave cylinder and bleed accordingly.
This should solve your problem.
Whenever a master cylinder is being replaced, always try to bleed it on the bench before trying to bleed the whole system, and your life will be a little bit easier :wink:
Lutz Kramer Clutch is disengaging slowly Austin Healey 14
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
S MGB 1978, replacing the clutch. MG 3
S MGB clutch replacement MG 7
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
D BJ7 Clutch Austin Healey 6
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
