Change LHD for MOT
mcjane
My 2nd post.. I have decided to take my LHD BMW F20 from Germany to the UK. Since I have to register with the DVLA, I have to make these changes:
1. Fix headlights so they dip to left (Mine are halogens).
2. Fix rear foglight (Default is rear left).
3. Put MPH speedometer.
Has anyone got experience with these changes. How difficult are they and if done at a garage how much they cost. Any help is greatly appreciated!
JPSmit
Good news, can I suggest though that you check a UK based forum? (Try retro rides) while this is a British Car Forum almost everyone on it actually lives in North America, so, it isn't that we are being unfriendly when we don't respond, we just don't know. In fact our issues are more likely getting RHD cars licensed in the USA and Canada. Do let us know though.
i wouldn't be surprised to find a British BMW forum either that might help with parts - good luck!
Grantura_MKI
Should not be a major issue. You will need to switch the headlamps to the UK units and move the fog lamp to the other side of the vehicle.
The speedo will be the difficult bit. This will more than likely need to be done by a BMW main dealer, as the mileage when changed, etc will need to be recorded for the DVLA.
Let us now how you get on.
D Overdrive Stops Working After Oil Change Austin Healey 26
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
D TR2/3/3A Why it is important to change brake fluid Triumph 4
C MGA Change a pull starter to a push button system MG 6
F TR6 Idle change when brake is pressed Triumph 4
TRMark TR4/4A Adapting to Change Triumph 8
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
T BJ8 Fan Belt Change Austin Healey 7
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
Michael Oritt How to change signature Austin Healey 2
R BJ8 Windscreen Change Austin Healey 2
PAUL161 why the change? FORUM Navigation Questions 5
M TR2/3/3A Engine change tooling Triumph 2
T TR4/4A Core Plug - Cam Rear change Triumph 7
B How often should you change the rear rear axle oil Austin Healey 9
G Gearbox and overdrive oil change Austin Healey 15
Got_All_4 TR2/3/3A Ingnition switch key change Triumph 7
dudley32 How to change or edit title on a thread FORUM Navigation Questions 2
R Master Cylinder change working Austin Healey 12
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
davidb AH 3000 - vinyl colour change Austin Healey 7
6TTR3A TR2/3/3A Production Change Triumph 7
Michael Oritt Oil Change Problem Austin Healey 27
M MGB trying to change rotors - dumb question MG 7
C Color change...impact on Value? Austin Healey 24
JPSmit How often do you change your spark plugs? Spridgets 7
Basil Admin Note One more little change MG 1
Brinkerhoff Painting or dyeing to change interior color? Restoration & Tools 2
E Oil Change Austin Healey 1
dcoplan Spark plug and oil change question Spridgets 9
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
toysrrus What? I`ll have to change my avatar again! Triumph 13
hondo402000 Oil Change Triumph 6
Moseso A simple oil change gone South Triumph 16
J Any reason to not change the color of a Sprite? Spridgets 10
Gliderman8 Oil Change.... When to do it? Triumph 17
Marvin Gruber T-Series TD diff change & wire wheels MG 9
Anthony_S Oil Change Triumph 13
5 BN4 cylinder head casting change date? Austin Healey 5
AUSMHLY When to change oil ? Austin Healey 12
N Head Change???? MG 2
Woodie TR6 tr6 oil change Triumph 5
Rut 1275 oil change Spridgets 6
G Oil Change after Storage - Part 1 - making a mess Austin Healey 0
drooartz Time for an oil change: filter and jack stands MG 7
F Change BE tach to electric Spridgets 3
