T-Series TD diff change & wire wheels
I've been asked by a local guy to help him put a taller geared rear end under his TD. Told him most folks use a MGA diff with TD axles to do that. He also wants wire wheels. Can he just use a MGA wire wheel diff and front hubs to do that.
Marv
DNK
Didn't we just discuss this??
or am I thinking of something else?
Wasn't it Paul who was concerned over the tall gearing in his?
drooartz
DNK
Know this discussion was somewhere.
Know Hap was involved
DNK
Drew, Didn't Paul ask what other rear he could put in that thing instead of doing the trans?
MGTF1250Dave
Aloha Marvin,
The rear track dimension of the two cars is different. The TD/TF is alittle over 2" wider than the MGA. I beleive you will have problems with the rear spring purches on the MGA rear axle assembly not aligning with TF's springs. It may also bring the tires in very close to the inner wheel wells. The more common swap is the 4.3 ring and pinion from the MGA into the TD/TF rear end. I think if the straight rear axle swap worked, many would not to mess with the gear change.
Here is a link to pretty good article on the gear change:
https://www.ttalk.info/RearEndConversion3.pdf
If your friend is going to use the larger diameter MGA brakes on the rear axle, he should also change the front brakes also.
drooartz
Paul said he had a 3.9 rear end -- which would fit but he was worried it might be too tall (ratio-wise) for the engine.
PAUL161
Hi guys! To clarify, I have an early MGB banjo rear with 3.9 gears. The gears in it will fit in a TD/TF rear housing with some shim and bearing changes. If the early B rear would fit under the TF by only adjusting the perch brackets, I'd try it just for a test bed for the 3.9 ratio. If the engine handles it with no problems, I'll pull the B rear apart and install the 3.9 gears in the TF housing and appearance wise, no one will know the difference. I want to keep the car looking as original as possible.
I would not put a 3.9 rear in a TD with a 1250 engine, a 4.3 is the most desirable, as I've been told. PJ
RJS Fluid Change Interval - Trans and Diff? Triumph 8
K TR2/3/3A Tr3: Change in Diff=Change in Speedo reading? Triumph 7
Shinsen774 Rear Diff Gear Oil Change Interval MG 2
VelodromeRacer Diff change instructions... Racing 4
A Spitfire How to change diff oil on 78 Spit? Triumph 1
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
Darwin GT6 Diff Help Please Triumph 2
skystryd Trans and Diff Spridgets 7
M TR4/4A Diff comparisons Triumph 2
N TR6 Triumph Diff which model??? Triumph 1
pbraun Wanted 3.9 diff for sprite Spridgets Classified 5
steve00136 MGB Diff refurbish MG 6
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
M TR4/4A Diff Conversion Triumph 3
T Diff Ratio BJ7 Austin Healey 5
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
K TR2/3/3A 3.45 Diff ratio? Triumph 7
B best diff British Motor Corp 5
wangdango '67 XKE rear diff? Jaguar 2
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
B diff ratio British Motor Corp 3
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Jim_Gruber Speedi Sleeve Install and New Diff Gasket Spridgets 5
69MGC MGC Diff Oil MG 1
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
drooartz Diff pinion nut Spridgets 10
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
R TR2/3/3A Lockheed diff setup Triumph 6
Boink 3.9 diff and pinion seal Spridgets 2
Boink 5 speed vs. 3.9 diff - either or both? Spridgets 165
Michael Oritt 3.54 diff for sale Austin Healey 1
drooartz Diff pinion seal Spridgets 8
Rut Diff plug tool Spridgets 7
Geo Hahn General TR Diff Pinion Seal Triumph 5
Geo Hahn TR2/3/3A Paint Dab on Diff Cover Triumph 6
A TR4/4A Changing rear diff seals Triumph 15
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
JFS Wedge Diff Cover Gasket Adhesive Triumph 10
G Diff and trans oil Spridgets 8
C TR4/4A Diff gear wear Triumph 10
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
K TR2/3/3A 4:1 Diff in a TR3? Triumph 3
steveg Limited Slip GM Healey Diff Austin Healey 4
DerekJ 11:39 Diff for sale. Austin Healey 0
H Noisy diff in BJ7 Austin Healey 2
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
