Any reason to not change the color of a Sprite?
JOeyKnapp
My 67 Sprite is Tartan Red. It isn't my favorite color. I will be repainting the whole car, so I was thinking of changing the color.
Is there any reason NOT to change the color? I don't think there is a color tied to the VIN?
Down the road if something happened and the spridget suddenly gained value would the color change hurt me? (there will not be any area not painted, and I am removing all the old paint as well..)
Thanks for any insight into this decision,
-JOey
Unless you plan on making the rest of the car factory correct, then paint it as you like and enjoy it. Paint is not permanent, someone else can change it later if they like.
RickB
I believe Heritage certificates list the color the car was when it left the factory. I could be wrong as I have not purchased one for any of my cars.
I believe you should paint the car a color that pleases you, these cars were meant to be driven and to put a smile on the owners face, as well as all who see them. Just my humble opinion. :smile:
Jer
your right Rick, the Heritage Certificate does show the original factory colour that car was shipped with, the sheet for my 67 shows basilica blue, sure enough around the edge of the tranny fluid check rubber plug I found some evidence of that colour, aside from that previous owner did a good job with the "fleet red" paint job, even got it under the dash etc.
But as Trevor mentions if your not going for all original, do what you like, these cars don't command high enough prices (yet) to worry about paint colour in my opinion... having said that, I want to return my 67 to basilica blue (because I like that colour for some reason), however my 74 will stay red because I'm not a fan of the original harvest gold ? (it think that's the name for that yellow'y orange colour...)
bthompson
JOeyKnapp said:
...if something happened and the spridget suddenly gained value...
:lol: HAHAHAhahahe hee ...er...ahem.
Yeah, no fear of that.
Bugeyes perhaps, but never run of the mill Spridgets.
JPSmit
Ahem! :nonono: I beg to differ, particularly in the case of the later Midget Big Blocks. :jester:
seriously, paint it whatever. (within tasteful reason) I was a common practice back in the day for dealers to repaint cars if the one in stock that the customer wanted was the wrong colour.
HealeyRick
JOeyKnapp said:
Wow, I have so much to learn.. I don't know anything about a Heritage Certificate...
Here's a link to the Heritage Certificate info: https://www.heritage-motor-centre.co.uk/store/index.php?dispatch=categories.view&category_id=169 As far as color changes go, I doubt there would be a huge loss in value if you stick with one of the other colors originally offered. Paint it Dodge Plum Crazy, however, and your potential audience of future buyers may be somewhat reduced.
jhorton3
Paint it what you want and have fun with it. No sense going for original on Spridgets unless you're going for a concours restoration, and I wouldn't advise doing that. I went with the original color based on nostalgia, as that color scheme matched the first Midget I ever got to drive when I was a teenager.
Sopwith_Camel
when i bought my third chassis I knew i wanted to build a coustom but i didn't know if i would want to drive it but every spring when the first girl smiles at me I am so happy that I dared to do it different!
Do what makes you happy and the whole world will smile back
trust me
steve
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
Rut Any reason not to mount this here? Spridgets 21
gbtr6 TR6 Reason for my rebuild Triumph 3
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
S Off Topic Reason 193 why I love little british cars [especially TRs] Triumph 8
RedTR3 TR2/3/3A The Reason for my Rebuild Triumph 5
R reason for it said 1500 has cooling [run to hot] problems? Spridgets 20
Jer Another reason why it's great to own a Spridget Spridgets 9
tahoe healey real reason for no tunes Austin Healey 21
germanmichel Reason of SU fuel pump strike Austin Healey 9
tony barnhill I know there's a reason, but... Spridgets 14
Trevor Jessie What is the reason for this Spridgets 9
JPSmit There's a reason I haven't - but a question Spridgets 12
jlaird For some reason Spridgets 5
jlaird Another reason Spridgets 8
J The reason stated the Esprit will disappear after 2003 is....[look inside to find out Lotus 2
D Overdrive Stops Working After Oil Change Austin Healey 26
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
D TR2/3/3A Why it is important to change brake fluid Triumph 4
C MGA Change a pull starter to a push button system MG 6
F TR6 Idle change when brake is pressed Triumph 4
TRMark TR4/4A Adapting to Change Triumph 8
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
T BJ8 Fan Belt Change Austin Healey 7
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
Michael Oritt How to change signature Austin Healey 2
R BJ8 Windscreen Change Austin Healey 2
PAUL161 why the change? FORUM Navigation Questions 5
M TR2/3/3A Engine change tooling Triumph 2
T TR4/4A Core Plug - Cam Rear change Triumph 7
B How often should you change the rear rear axle oil Austin Healey 9
G Gearbox and overdrive oil change Austin Healey 15
Got_All_4 TR2/3/3A Ingnition switch key change Triumph 7
dudley32 How to change or edit title on a thread FORUM Navigation Questions 2
M Change LHD for MOT Other Cars 2
R Master Cylinder change working Austin Healey 12
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
davidb AH 3000 - vinyl colour change Austin Healey 7
6TTR3A TR2/3/3A Production Change Triumph 7
Michael Oritt Oil Change Problem Austin Healey 27
M MGB trying to change rotors - dumb question MG 7
C Color change...impact on Value? Austin Healey 24
JPSmit How often do you change your spark plugs? Spridgets 7
Basil Admin Note One more little change MG 1
Brinkerhoff Painting or dyeing to change interior color? Restoration & Tools 2
E Oil Change Austin Healey 1
