Carb Overhaul for retro fitted 1954 100M
ianh
Hi,
Having remortgaged the house to get through the suspension rebuild, gearbox failure, 6 months of various and unpredictable brake failings and a blown head gasket my joy at the first trip out was short lived with fuel flooding out the top of the carb float chamber, low voltage warning light back on (only bought recon dynamo 6 months ago) and a cracked windscreen !!!!
I understand the overflowing float chmaber is a 'known' problem of sticking cutoff needle above float.
I was planning to replace these but got odd question about whether they are normal or rich running ? Anyone know how to tell ?
Is it a good idea to change them ?
What else should I change whilst tinkering (Gaskets look shot and I am keen to do preventative maintenance but without going too far and screwing everything up !)
Any tips on putting in new windscreen ?
Daren't ask about the battery charging light ! I went right round that loop 6 months ago and needlessly bought an overhauled dynamo when probably should have just re energised coils !
Thanks as always
Ian
Keoke
Ian, The needle valves are driven by the floats and regulate the Petro to the carbs. Additionally. there are also needles which operate under the depression in the carbs which control the fuel mixture, it is this set of needles that can be selected to produce leaner or richer fuel mixtures. Dirt in the fuel or wear in the needle valves can cause the flooding you experienced. About the windscreen;you got insurance?, well just hop down to the pub and leave the car home but out side and have a couple of your buddies pop over and break it up good. I leaned this trick from some rotten buggers over there in the UK.--Keoke- /ubbthreads/images/graemlins/grin.gif
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
2 TR2/3/3A SU carb. Acts like an expansion valve ! Triumph 10
dbenichou289 TR2/3/3A SU carb linkages Triumph 2
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
O HD8 carb on Healey 3000 Austin Healey 62
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
R TR2/3/3A Carb throttle return spring tension Triumph 2
drooartz MGB Troubleshooting Mikune carb MG 33
