Brosky question
KAllen
Hi Brosky
Did you use por15 on the entire differential? The pics look like you did - and have you tried the Hirsh miracle paint? I have more of that than the POR and I need to do the undercarrage now that the differential is out.
I thought that I answered this earlier. Let me put it this way; If it wasn't powder coated and it couldn't run and hide, it got coated with POR15.
I used the Hirsch paint on the insides of my fenders about 15 years ago. It seems to be holding up well, though my car is far from a daily driver.
Kim,
To be honest, I never heard of it until now. Hmmm, maybe for the next restoration project??
Not me, maybe Bill or Tom, or you, perhaps?
Hi Darrell; It goes on very similar to the POR15 stuff maybe a bit thinner - Just finished coating the differential and underside with it 2 coats - gotta remember to wear gloves - the stuff does not like to come off even with acetone! A badge of some sort eh!
Hi Paul - it is very similar to POR It hardens like it - cannot resuse the container once opened - like POR - so chemically - a polyurethane that cures with moisture - just seems a bit thinner to me - but I am brushing it on so - if I sprayed it on - I may notice other aspects.
Getting ready to RR the pinion seal - looks straight forward from the Bentley manual - any comments to help?
Kim
Mickey Richaud Hey, Paul [Brosky] - Triumph 2
B Brosky's right!! Triumph 20
drooartz Brosky, nice bit in the papers! Triumph 12
angelfj1 Brosky Off-Road Services Triumph 4
B for brosky Triumph 3
T Post-War Other Brosky, can you rebuild the TRF Italian fuel pump? Triumph 17
T Dang You Brosky....I'm Red All Over! Triumph 6
BobbyD Bet We Won't See Brosky Do This Triumph 19
LastDeadLast Brosky - Front sealing block info? Triumph 15
jerrybny Brosky Sighting?? Triumph 1
T Brosky Triumph 5
T Mr. Brosky's Springs Triumph 4
G Brosky, any feedback on the Spal fan??? Triumph 1
G Brosky, ya got a picture of dizzy drive gear set.. Triumph 10
2wrench Exhaust manifold studs, Brosky Triumph 4
G Hey Brosky! Triumph 1
T calling brosky Triumph 1
N Brosky requested Progress Report Triumph 2
LastDeadLast Woah, Woah! Brosky, I need a needle! Triumph 10
G The woes of high performance...listening Brosky??? Triumph 12
DrEntropy YO! Brosky!!! [RE: Throttle linkage couplings] Triumph 15
Basil Brosky! Triumph 3
M MGB Disributor clamp question MG 1
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
