Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Did you use por15 on the entire differential? The pics look like you did - and have you tried the Hirsh miracle paint? I have more of that than the POR and I need to do the undercarrage now that the differential is out.
Hi Darrell; It goes on very similar to the POR15 stuff maybe a bit thinner - Just finished coating the differential and underside with it 2 coats - gotta remember to wear gloves - the stuff does not like to come off even with acetone! A badge of some sort eh!
Hi Paul - it is very similar to POR It hardens like it - cannot resuse the container once opened - like POR - so chemically - a polyurethane that cures with moisture - just seems a bit thinner to me - but I am brushing it on so - if I sprayed it on - I may notice other aspects.
Getting ready to RR the pinion seal - looks straight forward from the Bentley manual - any comments to help?
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
