Brake Rotor Clean Up
boeingpilot
I'm restoring a GT6 and I had a quick question. The rotors are in very good shape, but the car sat for a while before I got it. As a result there is some surface rust on the rotors. Other than that they are fine. What's the best way to clean 'em up?
PAUL161
I'd just pull them and take them to your local brake shop and have them true them up. The rust will be gone, naturally, and you'll have a true running pair of rotors with no surging. Use new "non-metallic" pads on them!
tony barnhill
Great Pumpkin - R.I.P
If they're not grooved, drive 'em....after the first few brake applications, the sdurface rust wil be gone.
Of course, there's nothing wrong with having a shop turn them just to be sure they're true like Paul said....
Steve_S
:iagree:
startech47
If the rotors are in good shape, except for the rust, just use some 80 grit sandpaper and knock the rust off. This will keep the pads fresher. If there is surface damage have them turned.
K TR2/3/3A Spacers to centre the the front brake rotor? Triumph 11
mrv8q TR2/3/3A TR 3A brake rotor size? Triumph 3
J EBC GD208 Brake rotor Austin Healey 5
J New brake rotor or get the old ones turned?? Triumph 12
H brake/rotor question Austin Healey 28
T Torque setting on brake rotor Triumph 4
D TR2/3/3A TR3 brake rotor question Triumph 4
W Spitfire Spitfire Brake Rotor Removal Triumph 4
L TR2/3/3A TR3 Brake Rotor Thickness Triumph 18
M XK150 Rear Brake Rotor Dimensions? Jaguar 1
19_again brake rotor replacement MG 12
vping Brake rotor questions MG 23
J Late BJ8 brake rotor- thickness specs Austin Healey 5
G Disc brake rotor removal Spridgets 17
C Brake rotor help Racing 3
C Brake Rotor search Other British Cars 9
C Brake rotor help Lotus 2
C Brake rotor help Racing 9
MadRiver Brake Rotor Recommendations? Triumph 11
Hegg Elan +2 Brake Rotor grind Lotus 2
K brake rotor alignment MG 5
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
