BN4 Ignition/Turn Indicator Light
rgfrey
Hello all,
I developed a new problem today. I noticed that the ignition indicator light in the center of the facia panel didn't go out after the car was up and running. In fact, the ignition indicator light stays on all the time. Later, when I used the directional indicator the ignition indicator light blinked once and then stayed on. This is occurring turning both left and right. When I got home I found the right front directional indicator bulb to be burned out so I replaced it. No change to the non-blinking problem. All four directional lights come on, they just don't blink.
Is there a way to test the flasher unit? I know Moss has new flasher units. I wanted to see if someone out there had any insight on this problem before I spent the money on the new flasher.
Thanks ahead of time for any input.
rob
I'm a bit confused.
When you say "ignition indicator light" do you mean the "no charge warning lamp" in the bottom of the tachometer? (I'm using the name in the shop manual.) It should have nothing to do with the turn signals.
The yellow (on my BN4) "flasher warning lamp" between the speedometer and tachometer should flash opposite from the directional indicator bulbs. If the respective directional indicator bulbs are on and the flasher warning lamp is also on, there is an electrical short between the L and P terminals on the flasher unit. Check and see if the wires for the L and P terminals are touching.
There really isn't a way to test the flasher unit because it needs the proper load on it (provided by the two incandescent on the right or left). If those have been changed to LEDs, the flasher unit won't work properly.
When I turn the key on and the fuel pump starts pumping, the light between the speedometer and tach. comes on (Warning Lamp according to the workshop manual) and should go off once the engine is running. After the engine was running that lamp would go off and only come on when the directional signal was engaged. Now that lamp stays on all the time and the directional signal lamps don't blink.
There is a small hole in the bottom of the tach. that says "Ignition" that allows white light to come through once the engine is running. That stays on as long as the engine is running currently. Is that "ignition" light the "No Charge Warning Lamp"? Maybe the generator is bad?
You do have a wiring problem then. The light between the speedometer and tachometer should only be for turn signals.
Additional:
If you are looking at the wiring diagram in the shop manual (Bentley), #24, Flasher warning lamp (the one between the speedometer and tachometer), should have a light green wire from the "P" terminal on the flasher unit (#21), and a black wire to ground/earth.
#37, No charge warning lamp (the one in the bottom of the tachometer), should have a white wire from the starter button, #23, and a yellow wire from post D on the Control box, #17.
The ladder logic diagram from Bill Young, > Electrical - Austin-Healey 100-6/3000 Electrical Drawing <, may be easier to follow. Click on the link and then click on the orange "download" button to see it. It shows better how the wiring works, but not how it's actually connected.
If you have a voltmeter, measure the voltage at post D on the control box with the car running. If it's greater than 13 volts, the generator is ok.
Problem resolved! Red wire on the right front signal lamp came lose and possibly shorted to another terminal or wire. Warning Lamp only comes on when the directional signal is engaged.
Thanks all.
rob
A 100/6 BN4 Restoration Austin Healey 8
A 100/6 BN4 Door Lock Austin Healey 15
zoohow BN4 Top Frame Installation Austin Healey 1
W BN4 Engine Mounts Austin Healey 2
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
P BN4 Generator Woes Austin Healey 7
W BN4 History Search Austin Healey 7
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
W BN4 Steering box bushing. Austin Healey 2
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
Hangtown Healey BN4 Front Springs Free Length Austin Healey 3
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
C 100/6 BN4 Soft Top Frame Austin Healey 16
A BN4 Hard Top Austin Healey 23
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
B Side window question for early Longbridge BN4 Austin Healey 4
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
B Longbridge BN4 top frame question Austin Healey 6
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
B BN4 Longbridge door panel question Austin Healey 4
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
longbridgehealey Removing BN4 Bonnet Austin Healey 9
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
Csarneson Early BN4 steering box pitting Austin Healey 16
Csarneson BN4 Cam Gear Install Austin Healey 3
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
K Correct side screen nut for early 58 BN4 Austin Healey 14
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
P BN4 Hesitates on Starting Austin Healey 12
Csarneson BN4 Wiring Questions Austin Healey 5
D Photos of Longbridge BN4 door seal track. Austin Healey 5
Bugeyze BN4 Windscreen Shims? Austin Healey 13
Csarneson BN4 Engine Rebuild Questions Austin Healey 8
G Wanted AH 100-6 BN4 Steering Wheel Austin Healey Classifieds 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
L 100/6 BN4 Brake fluid Austin Healey 17
L 100/6 BN4 Hood fittings Austin Healey 5
MisterB Shut pillar differences? BN4 to BJ8 Austin Healey 7
L 100/6 BN4 Fuel Tank feed Austin Healey 5
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
T Dunlop 4 wheel Disc brakes on BN4 Austin Healey 11
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
L Need a early BN4 hood bow Austin Healey 1
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
