sunkissedhealey
Greetings,
I had one bad horn (high note)on my BJ8, and so I sent them both (MAW syndrome)off for restoration to British Car Part Restoration in Mass. I've got some crummy replacement horns that will work in the place of the original Lucas horns until I get mine back from restoration. These replacement horns have some custom made brackets--they work, but the "bell" of the horn points out at a 45 degree angle. My question is: is the high note forward (or aft), the low note aft (or forward)? To make this clear, aft is facing towards the firewall, forward facing towards the radiator. With the bracket as is, they could be mounted either way. The horns are an embarrassment, and so I'll keep my bonnet closed until I get the originals back.
Rob
Rob
