TR2/3/3A Bearing Failure?
karls59tr
Bronze
This happened a couple years ago. I survived. Would like to hear some theories on this catastrophic bearing failure happened. After I hear your opinions I will give you my theory on how it happened.:encouragement: 100_1773 (1).jpg100_1778 (1).jpg100_1780 (1).jpg100_1781.jpg
Merlin63Tr4
From the looks of it, it looks like you had a dragging brake which overheated the disk and cooked the grease in the hub and caused the wheel bearing to fail.
Clues are the blueing of the brake disk and the stub axle.
M.
Madflyer
I agree also the real question is did the seal go bad first was the grease old and sat not running for a time. I 1/2 fill the body of the hub so if heat gets to grease it should melt more into bearing. There is another Thread about loading on wheel bearings . Madflyer
K
karls59tr
Bronze
Well here's the story: I had taken the the front pass side wheel off for some reason and I remember repacking the wheel bearing.I had the nut installed on the spindle and was about to adjust it when I was called away on a family emergency. I scribbled a note to myself to check the wheel play when I got back and left the note on the work bench. I didn't get back to the car for a few days and the note must have blown away! Anyway a few days later I was out on the highway going 65mph when the left front wheel tilted inward about 30 degrees and jammed the brake caliper against the rotor and locked up the wheel. I managed to skid the car to the side of the road and took a look under the car. There was a grease fire at the inner side of both wheels. I threw gravel on flames to put them out. Quite the adrenaline rush! Luckily I had spares for all the damaged parts. Like Madflyer said I may have forgotten to load up the body of the hub and that might have caused the failure. I was wondering if having the bearing too tight or too loose would have exacerbated the problem? The spindle nut was still in place? Any thoughts?
CJD
I noticed you never got back to your wheel bearing thread. The cotter key was installed...
T TR2/3/3A Bearing failure Triumph 27
R Bearing Failure Guide Triumph 2
S TR2/3/3A Pinion tail bearing replacing Triumph 12
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
AUSMHLY 1st Motion Shaft Bearing Austin Healey 7
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
C Spitfire rear wheel bearing Triumph 2
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
charlie74 TR6 Bearing cap bolts Triumph 8
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T crankshaft (rear) bearing leak Spridgets 2
red57 Rod Bearing Clearances Austin Healey 4
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Lin Cause of burned wheel bearing? Austin Healey 5
J General TR Main bearing caps Triumph 6
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
B TR4/4A Front cam bearing Triumph 8
A Front wheel bearing issues Austin Healey 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
R Center Gearbox Input shaft bearing Austin Healey 9
S TR2/3/3A TR3 clutch release bearing... from Home Depot? Triumph 12
B TR4/4A What really is the best clutch/bearing combo Triumph 4
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
M Wheel bearing question Austin Healey 9
JPSmit Midget Thrust bearing coonversion Spridgets 9
B Clutch Release Bearing Austin Healey 2
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
Bayless Need wheel bearing advice please Spridgets 4
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
H For Sale Rear end bearing and seal set Austin Healey Classifieds 0
R Main Bearing Cap Removal Austin Healey 12
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
warwick-steve Front hub bearing grease repacking Austin Healey 28
T TR2/3/3A H6 jet bearing seals Triumph 3
R Clutch Throwout Bearing Noise? Austin Healey 2
C Size of axle bearing nut Austin Healey 11
R Front wheel bearing - end float Austin Healey 40
