Altette horn rebuilder
steveg
I only have one horn, which recently stopped working.
Will be taking it apart to see if I can clean the points, but may need to have it professionally rebuilt.
Does anyone have experience with:
British Car Part Restoration
Peter Gigliotti
8 Leonard Road
Walpole, MA 02081
They evidently specialize in Lucas horns.
Steve,
I used the same company when it was run by E. Lawrie Rhoads. They did an excellent job on my horns and wiper motor.
Additionally, the Lucas workshop instructions for the HF1746-47-48 can be found here:
https://rhynard.org/images/AH/horns.pdf
Thanks,
Duane
'58 BN6
Peter Gigliotti
8 Leonard Road
Walpole, MA 02081
Steve,
Thanks,
Duane
'58 BN6
Duane,
Thanks for the pdf link! I used it to remove the disc and diaphragm. Inside was immaculate with nothing obvious wrong or broken. Afraid I'll mess it up, so will send if off to be overhauled.
C TR4/4A Horn button and brush assistance Triumph 14
glemon TR5/TR250 Horn Problems Late TR Triumph 12
JPSmit sometimes there is no point in sounding your horn. Spotted 3
P TR6 Horn issue 1974 TR6 Triumph 5
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 11
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A The horn and turn signal assembly. Triumph 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
R Horn relay Spridgets 2
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
P TR6 TR6 Horn Relay Problems Triumph 8
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
K Restoring Horn Push Button Austin Healey 12
Jim_Gruber Intermittent Horn Spridgets 2
Joe_Healey TR5/TR250 Bubba Horn Triumph 0
G TR4/4A Horn Brush Question Triumph 7
edkap2002 TR6 horn brush Triumph 3
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
Jim_Gruber In need of a really loud horn Spridgets 13
T Lucas HF 1748 horn parts Austin Healey 5
