TR6 '72 Engine Project, Some Day
Martin Secrest
My '72 has almost 90K on the odometer, and while the engine runs fine and doesn't really drink (oil) or smoke, I'm pondering an engine rebuild in the next year or two. Not a project I *want* to do, but I would be happy to get it done and drive the car until the end of time. The rest of the car is very sold and completely sorted, so the engine is kind of the last shoe to drop. If I do the rebuild, I'll be adding some reasonable amount of horsepower, with head work and a cam swap. Probably will stick with the twin Strombergs, but who knows.
So my question is ... what are lessons people have learned in the past for this? Pitfalls to avoid? Things to do right the first time, etc. And though I have never seen anyone do it, or even talk about it, is it possible to rebuild the engine in situ? I mean, I have to ask.
poolboy
It depends. If you need to have the cylinders bored for larger pistons rather than just crosshatched honed for fresh rings and the same size pistons an/or if you need to thave the crankshaft turned for oversize bearings, you will need the engine out.
The only tip I have at the moment is to use Hastings piston rings, even if you have to buy them separate from what brand may come with new pistons
glemon
My engine was rebuilt at 90,000 ish miles (though I had no documentation of actual miles or previous work). A few disjointed notes. It didn't need a rebuild. We replaced bearings and piston rings with standard size, wear was not bad at all.
If you decide not to rebuild do check the crankshaft end float, lots of information out there on the internet.
I went a similar route to you on performance. Shaved the head, sports exhaust, mild cam, lightened flywheel, made a noticeable difference in performance with no sacrifice in driveability. If you are having head work done shaving the head is probably the best bang for the buck modification. Ups HP and Torque across the board, no drivability trade-off.
Bob Claffie
My standard answer. If it ain't broke, don't fix it".
M
Martin Secrest
Interesting responses. Actually about 10K miles ago I freshened the bottom end bearings, all of them, though I'm not 100% sure I did the best job. I was concerned about the idea of just pulling the head and porting and shaving it, what the extra stress of that increased HP might do to the engine as a whole. But maybe nothing?
poolboy
A freshened head, shaved to increase compression, valves and seats recut, seated and sealing tight might contribute to increased blowby and oil consumption past rings with 90k miles on them....I say 'might' but I bet you'd notice it.
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
B MGA My MGA project w/Datsun engine? MG 19
rlandrum TR2/3/3A TR3A Project: The Engine is in Triumph 18
vping Starting an Engine parts list - Winter Project MG 6
Camshaft New Project: Engine Pre-Oiler MG 15
RSMTR8 Wedge TR8 Engine Project Completed Triumph 5
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
